Why after 10k miles are my spark plugs burnt?
Discussion in '1st Gen. Tacomas (1995-2004)' started by John Cheong, Feb 14, 2012.
  1. Feb 15, 2012 at 7:15 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Who changed the plugs? It looks like they've been broken.
  2. Feb 15, 2012 at 7:16 PM
    Rashnu
    Rashnu Well-Known Member
    '16 T4R TEP
    Stock
  3. Feb 16, 2012 at 2:46 PM
    John Cheong
    John Cheong [OP] Active Member
    East Bay, CA
    2001 SR5 PreRunner
    33" falken rocky mountian A/T, 3.5" fabtech lift, Deck plate mod, Painted badges.
    they didnt have oil on them when i took them out but i looked at the link and it said it could be from a leaking valve cover gasket and oil is leaking onto them and making that burn mark...makes sense. my valve cover is a little leaky.
  4. Feb 16, 2012 at 2:50 PM
    John Cheong
    East Bay, CA
    2001 SR5 PreRunner
    and it has 189K on the truck
  5. Feb 16, 2012 at 5:32 PM
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    That sounds reasonable to me, that would explain why all 3 on the same side are the same and the other side isn't... I'd highly recommend changing that valve cover gasket!!!
  6. Feb 17, 2012 at 8:02 PM
    John Cheong
    East Bay, CA
    2001 SR5 PreRunner
    yeah ill change it when i have time. thank you guys for advise
  7. Dec 14, 2017 at 8:27 PM
    DeppraVacion
    DeppraVacion New Member
    Hello,
    I think I can help you.
    That burnt ceramic looks exactly like what I just pulled out of my 3.4 4runner.
    I’m certain it’s from a failed plug wire arcing to the plug.
    Long story short, I had developed a miss fire on cyl 4 yesterday, a p0304 code.
    I was aware that had an ignition coil been bad it would have shown two cylinder missfire. “Waste spark system “
    These engines utilize 1 coil for 2 cylinders. Blah blah blah... I wanted to check the functionality of the wire itself and found it to no longer insulated and arcing wildly. It also had a small tear...
    I’m aware this thread is old af, but for the sake of having resolution I figured I would chime in.
    Luv my yota and lucky13don like this.
  8. Dec 15, 2017 at 2:06 AM
    Rburdeaux
    Rburdeaux Well-Known Member
    2004 Double Cab Prerunner
    what temperature is considered running "hot"
    10tacosr5 likes this.
  9. Dec 15, 2017 at 2:19 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Don't forget to do your spark plug tube seals, half moons, and fipg the corners of your gasket where it goes over the cam humps.
  10. Dec 15, 2017 at 2:26 AM
    Key-Rei
    Key
    Florida
    Looks like typical 3.4 oil burn on the plug to me, the boot comes down to the "burnt" part keeping that area clean. What your seeing is what happens when your spark plug tube seals begin leaking and the oil mist hits the hot ceramic plug body and carbonizes or "burns" onto the plug. Have a look at your boots and see if they have any brown or black semi crispy residue on them, the wide top of the boot just below the 90° bend where the wire come into it seals against the valve cover, but the tube seals leak into that chamber created between the boot seal and the spark plug itself, the bit that isn't covered and ia hottest causes the oil mist to condence and give you what you see there.
    The plugs themselves should still be good.
    OP also check your PCV valve, or replace it for cheap insurance. You may also try the oil cap blowby check to get an idea of ring condition and PCV flow.
  11. Dec 15, 2017 at 2:32 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    OP hasn't been on TW since 2012 :boink:
  12. Dec 15, 2017 at 2:34 AM
    Key-Rei
    Key
    Florida
    Ahhhhh fek.... Kuffered again...
  13. Dec 15, 2017 at 2:36 AM
    Key-Rei
    Key
    Florida
    Guy was last on in 2012, don't worry I fell for it too...
  14. Dec 15, 2017 at 4:36 AM
    standard
    standard Well-Known Member
    David
    Delaware
    2003 Tacoma Double Cab
  15. Dec 15, 2017 at 6:15 AM
    #35
    DeppraVacion
    I noted in my OP that I was aware of the thread’s age homie, read with more care as I did not “fall for it”
    However, consider the fact this thread was found from a google search on the first page... so more people than just you or I are actually viewing it.
    The value of forums in my opinion comes from the bank of stored resolutions.
    It’s a huge drag when nobody takes the time to finish the thread.
    Peace ✌️
    standard and Key-Rei[QUOTED] like this.
  16. Dec 15, 2017 at 6:50 AM
    #36
    standard
    David
    Delaware
    Please don't use logic and being a contributor to the knowledge base that is TacomaWorld as a means to kill my attempt to find humorous memes and inject them into a legitimate conversation.
    Seriously though man, adding valid info to a thread that comes up on a Google search - especially as your first post - is awesome. Hope you keep contributing!
    lucky13don and zbadboy like this.
  17. Dec 15, 2017 at 2:09 PM
    #37
    DeppraVacion
    Cheers to that
    standard likes this.
  18. Dec 15, 2017 at 9:09 PM
    #38
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    :poking:It's obviously low on blinker fluid.
