why are leveling kits so bad ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tuumbaq, Feb 26, 2012.
  1. Feb 26, 2012 at 8:56 AM
    tuumbaq
    tuumbaq [OP] New Member
    Hey guys, new kids on the block here and I could use some help building my new truck.
    So, just bought a 2012 TRD double cab and Im debating wether I should go with a leveling kit or buy new shocks.I will be transferring my 6 months olds Toyo M/T 285/75R16 on it which should give me a bit more "cush" than the shitty stock tires...
    Before you guys say "not another cheap lift questions" Ive search the forum and couldnt find a good answer to this : why are leveling so bad?
    In short, the truck will spend 80% on its life on paved roads and the rest on gravel roads.All Im looking for here is to make the truck look a bit less stock and hopefuly meaner a bit ;)
    Now I get that for serious off roading the shocks are FAR better but for "look" purposes, why are the block so bad for the ride?I have to admit some of the gravel roads around here are punched with severals potholes but from my understanding even the 5100's wouldn't make a different floating on top @ high speed...Am I right ?
    If I decide to go with the shocks, what should I go with if Im only hoping to make the truck look better ? Could I just go Bilstein 5100 up front? Same coil and keep the rear stock?Im not too sure why most Bilstein 5100 kits out there comes with the rear shock with zero adjustably...??Why bother if doesnt give you any lift ?
    Also , I had the dealer agreed to install the leveling kit @ no cost, ( said it should be a 2 hr job) but if I were to choose to install new shocks up front , Id probably need to pay the extra time, is it a lot more labor to install shocks ?
    Again, Im new here, sorry if my questions seems silly.
    Thanks!
  2. Feb 26, 2012 at 9:01 AM
    Large
    Large Red
    If you use blocks and hardly off road you'll be fine, but why not go with 5100s ? The price difference is miniscule and you'll be far happier. On another note if you want to leave the ear stock and only lift the front you'll have a hell of a time cramming the 285s in the wheel wells.
  3. Feb 26, 2012 at 9:02 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    If your gunna do pavement most of the time spacers are fine bits a rough ride on and off road but if your on the street a lot like I said its fine
  4. Feb 26, 2012 at 9:04 AM
    Large
    Large Red
    IMO, use 5100s all around, front at 2.5, use a 1/2" or 2" AAL for the rear & align. If alignment #s are off use aftermarket UCAs.
  5. Feb 26, 2012 at 9:24 AM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    5100s all around from DownSouth motorsports = $300
    Rear aal $75 or better progressive AAL from someone like Wheelers = $150
    so you can pay around $450 for better quality and great ride or. . .
    I'm assuming block kit = about 3 hundo or more for crappy ride and low quality.
    Spend the extra couple of bucks, even if it is a street warrior why not have a nice ride and ability later on if you ever wanna haul some dirt bikes or lumber or do some wheeling.
    That's my. 02
  6. Feb 26, 2012 at 9:50 AM
    SPENCAF
    SPENCAF Well-Known Member
    Shiloh, IL
    2012 TX PRO 4X4
    AFE Pro dry filter, AttennaX, bed liner on front skid plate, AVID sliders, AVID light bar, KONG Storage Box, OME 2.5" 885 coils 1.5" AAL 265/75R16 Guard Dawgs
    If you can afford a brand new pickup I think you could afford to put a real lift on. The way I look at is you have an awesome truck, why complement it with a shitty high school freshmen block lift. Do yourself a favor wait a while save up some extra coin and buy yourself a high quality lift to complement your high quality truck. My .02
    Dirty Harry and ISAN_TACO like this.
  7. Feb 26, 2012 at 10:01 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I was intially going to do just the front with 5100s because I needed the clearance for bigger tires. I ended up doing all four (stock coils) and I'm damn glad I did. Even on-road it makes a big difference in ride quality especially in cornering. With all four and the rear spring TSB, it makes hitting deep cracks in the pavement a little harsh with no load, but I'll live with that because the pros far outweigh that one small item IMO.
  8. Feb 26, 2012 at 10:26 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    My truck is mostly on the street but I still refused to use blocks or spacers.
    And just leveling it out you're going to have fun fitting 285's. Even with a 3" lift trimming needs to be done.
  9. Feb 26, 2012 at 11:05 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Doesn't ride as nice. Loads of people run em though and seem happy.
  10. Feb 26, 2012 at 12:58 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    http://www.camburg.com/toyota/00-06-tundra/read-before-buy-spacer-lift/
  11. Feb 26, 2012 at 1:05 PM
    tacoma2010trd
    tacoma2010trd Member
    Been running front leveling spacers with the rear TSB for a while now and no problems. I've also noticed no difference in the ride at all. Whatever works for you...
  12. Feb 26, 2012 at 2:19 PM
    Forewheel
    Forewheel Active Member
    Corpus Christi, TX
    '11 DC SB TRD Offroad
    Bone Stock.....for now.
    I'm in the same boat, my truck rides the same as it did before, and yes, I do 90% of my driving ON road. Also, the spacer kit cost me a total of $75 out of my pocket and they are easy as hell to install, TSB was free other than they had my truck for half a day. No comparison in price to doing 5100's all around..
  13. Feb 26, 2012 at 4:40 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Touche, I thought they were much more spendy
  14. Feb 26, 2012 at 5:13 PM
    Large
    Large Red
    Nah they're cheap & gives more clearance for bigger tires but I'd spend a bit more for better quality. OME 884, 885, or 886 = $150, AAL = 75, DIY install, much better than spacer/block setup.
  15. Feb 26, 2012 at 5:18 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    It's a big boat. Im on deck 3. 99% on road.
  16. Feb 26, 2012 at 5:27 PM
    tuumbaq
    thanks guys, some got info there. Im most worried about crapping out my ride but it sounds like I'd be fine with the blocks...
    Sure it may be a new truck but Im also buying a canopy, wheels, tires and like all of us I have other bills to pay ;)...if I could save a few hundos and use them somewhere else it wouldnt hurt.
  17. Feb 26, 2012 at 7:26 PM
    Daytona Taco
    Daytona Taco Great Job!!
    George
    Daytona Beach
    07 prerunner TRD OR
    billy 5100s, eibach springs, spidertrax spacers, Black badges, grillecraft upper/lower black mesh, off road lights behind grille, paint trd rims, bhlm, lower valence black, grille surround black, 8000k hids, magnaflow side exhaust, carbon fiber vinyl inlay on trd logo, led interior lights and tag lights, tow hook, CB and PA
    Bob, whatre your billys set to? 1.75?
  18. Feb 26, 2012 at 7:48 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
  19. Feb 26, 2012 at 7:50 PM
    TexasTacoma37
    Pretty much sums it up. No way to argue with that
  20. Feb 27, 2012 at 10:58 AM
    Bobbb
    Bob
    Bob
    Bob
    Tundra TRD/OR
    Yep. Wanted to bring the front up a bit, but not make the rear any higher than the TSB did. Have overhead clearance issues to deal with.
