why are my speakers popping/crackling?
Discussion in 'Audio & Video' started by mikeyp6679, Feb 16, 2011.
  1. Feb 16, 2011 at 7:10 PM
    mikeyp6679
    mikeyp6679 [OP] Active Member
    '10 4x4 TRD Dbl Cab
    I am getting a terrible popping/crackling sound coming from my front components when I turn the volume up. It does not do this when the volume is low. It sounds horrible. Im running my front components through an amp and the rears off of the HU. Possibly an issue with grounding? I have the amp grounded to a seat bolt. Im running RCAs alongside power but Id rather not start this debate. I inly have the gain turned up only 25%. Does anybody have any ideas???
  2. Feb 16, 2011 at 7:20 PM
    JDattilio
    JDattilio Active Member
    Jayson
    SR5
    factory radio with a loc or aftermarket radio?
  3. Feb 16, 2011 at 7:34 PM
    mikeyp6679
    '10 4x4 TRD Dbl Cab
    aftermarket HU.
  4. Feb 16, 2011 at 7:46 PM
    JDattilio
    Jayson
    SR5
    hmm... what model amp and speakers? Could be ground, double check it reclean it, needs nice clean metal I've seen rusty grounds in the past cause issues with amps..... Sounds more like possible issues with the speakers themselves, has this happened from day one, or just started after a amount of time?
  5. Feb 16, 2011 at 7:52 PM
    mikeyp6679
    '10 4x4 TRD Dbl Cab
  6. Feb 19, 2011 at 12:38 PM
    mikeyp6679
    '10 4x4 TRD Dbl Cab
    Anyone have any other ideas or suggestions? I have checked all leads and ground at seat bolt. Voltage there is 12.10v. I tried different RCAs too..no difference. Im pulling my hair outover this. Speakers sound like crap...only happens when the volume is turned up.
  7. Feb 19, 2011 at 1:18 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Sure you're not just overdriving them? Set your crossover to 40hz (HP)on the amp and see if it still does it.
  8. Feb 20, 2011 at 12:03 PM
    mikeyp6679
    '10 4x4 TRD Dbl Cab
    Yes im an idiot and had the tweeter and woofer connections switched. Its all good now. What is ideal for the HP on the amp?
