why buy a Receiver Shackle when you can just make one for $10??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cmatt1605, Apr 17, 2011.
  1. Apr 17, 2011 at 4:48 PM
    Cmatt1605
    Cmatt1605 [OP] Well-Known Member
    Cody
    Mount Pleasant, South Carolina
    Squeaky leaf fix
    just wondering why would anyone buy a receiver shackle, when they could just make one out of a receiver and a normal shackle instead of a ball??? is there any cons from doing this??? i have two pics to clarify what im talking about.
    the $50 part:
    V.S the $10 part:
  2. Apr 17, 2011 at 4:54 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    You could put ur tow strap into the receiver around the bolt that holds the ball into the receiver too
  3. Apr 17, 2011 at 4:56 PM
    rcbs204
    rcbs204 Well-Known Member Vendor
    That is what i have always done, works great!!
  4. Apr 17, 2011 at 5:03 PM
    Cmatt1605
    Cody
    Squeaky leaf fix
    i would normally do that too, but my tow strap is just over 4" wide (old navy tie down strap for airplanes, similar to the ones the big rigs use to tie down loads)
    but are their any down flaws to doing the shackle this way?? i just had an extra receiver laying around the house.
  5. Apr 17, 2011 at 5:10 PM
    smileyfish
    smileyfish Well-Known Member
    mark
    mass
    trd sport
    none YET
    departure angle, the $50 piece sticks out just enough for the d ring, yours sticks out 4-6" past and is lower. you loose some angle and more likely to hit it.
  6. Apr 17, 2011 at 5:16 PM
    Cmatt1605
    Cody
    Squeaky leaf fix
    ohhh ok gotcha, i dont take mine off road all that much, tires arnt really made for it. i just pull a lot of people out, so that should be fine :D
  7. Apr 17, 2011 at 10:08 PM
    JKD
    JKD Well-Known Member
    I do what you do; remove the ball, put in the shackle.
    If you need departure angle, turn the receiver upside down.
  8. Apr 17, 2011 at 10:18 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    It's only $50. It's not like it's $500. It's not like they go bad.the shackle doesn't stick out as far as your set up.I've had my shackle Probally close to 15 years.hasn't been used in years but I keep it around.
  9. Apr 17, 2011 at 10:21 PM
    DubVtundy
    DubVtundy ERMAHGERD
    Thayer
    Keyser West Virginia
    2010 white double cab
    8 inch alcan custom leaf packs, ome 885's powdercoated white, bilstein 5100's all the way around with 12 inch travel on the rear, Light Racing Upper Control Arms, Sway bar removed, 17x9 kmc strike. 35x12.50 nitto Trail Grapplers. Satoshi Grill made by (homertaco), Black Headlight housings,retrofits, Tinted Tailights, color matched grill, Bought a TRD sport hood,elite off road front plate bumper,elite off road sliders, 13% tint on the front windows, 5% on top of the facotry rear windows and back glass, 5% tint stip across the windshield, Lo Pro Truxedo tonneu cover, Herculiner bed liner, Weather Tech Window Visors, Exhaust- Flowmaster Super 44 dumped above rear axle, Maglight Mount on side of drivers seat, Scangauge II, Mossy Oak Camo Seat Covers, Weather Tech Floor mats, Spatter painted A-Pillars, Spatter painted headunit trim and shifter trim, Headunit= Pioneer 4300 double din touch screen, Speakers- Precision Power 3 way component stage, Precision Power 8 i
    you dont even have to spend 50 bucks i bought one off ebay that was solid steel with a shackle for 25 bucks i would rather just have a normal shackle and a normal hitch
  10. Apr 18, 2011 at 3:16 PM
    lrak
    lrak Well-Known Member
    The Reese / Tow Ready / Hidden Hitch model 63046 receiver shackle is only $25 delivered and has a higher working load than the "$50 one" pictured.
    Where do you both the shackle with quick release pin and hitch for $10? That's a great deal.
  11. Apr 18, 2011 at 3:25 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I got my receiver piece with the hook at HF tools for $15, I keep three different heights of receivers around since I have three different trucks with receiver hitches.
    Howard
  12. Apr 18, 2011 at 3:27 PM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    ... but good idea!
    and couldnt you fit the actual shackle pin through there instead of that hitch pin or whatever it is?
  13. Apr 18, 2011 at 3:31 PM
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    I just stuff the end of my towstrap into the female receiver and put the pin through it. I don't know if it's recommended or not, but it's never failed or bent the pin in 25 years of doing stupid, destructive things to the vehicles I rely on daily!:D:eek:
  14. Apr 18, 2011 at 3:36 PM
    ggreen
    ggreen Well-Known Member
    North Bay Area, CA
    2010 MGM TRD Sport DC Shortbed 4x4
    Icon Suspension Lift, TRD Cold Air Intake, TRD Exhaust (Powder Coated Black), Wet Okole Seat Covers, Weathertech Mats
    I just bought a receiver shackle for $11.99 on Amazon. It was new but in an open box. Not a bad idea though if you can't find a good deal and don't want to spend the extra coin....
  15. Apr 18, 2011 at 3:45 PM
    singlefin
    singlefin Well-Known Member
    Portland, OR
    Syncro
    Same here, however you have several more years of it.
  16. Apr 18, 2011 at 3:59 PM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    yeah the OP said hes using a 4" strap already
  17. Apr 18, 2011 at 3:59 PM
    SAIRS
    SAIRS Well-Known Member
    Kelly
    Utah
    Super White 2012 Double Cab LB TRD SPORT
    Icon Extended Travel Stage 1, Total Chaos UCA's, Dakkar leaf pack, Beefed DCLB Sliders with extended kickout and custom BSP, Beefed Custom exo-rear tube bumper, Toyota bed mat, tailgate theft mod. Front mudflaps removed, Access LE soft tonneau cover, Weathertech digital floor mat, Weathertech window deflectors, Weathertech license plate frames. future plans = diamond plate tailgate mod, Venture Shield, TRD supercharger...the dream goes on and on....
    I didnt know Old Navy :eek: had tie downs. :notsure: I wouldnt trust em personally, but thats just me yuk yuk
  18. Apr 18, 2011 at 4:01 PM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    lol
  19. Apr 18, 2011 at 4:02 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    I only paid like 20 bucks for mine. Looks better IMO. I guess as long as it works that's all that matters. But I usually keep my shackle in when it's not summer and I don't have the receiver ball in for my boat.
  20. Apr 18, 2011 at 4:05 PM
    singlefin
    Portland, OR
    Syncro
    That's a pretty wide strap. I just have a 2x30.
