why did my mpg go down
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07txtaco, Sep 3, 2010.
  1. Sep 3, 2010 at 7:13 AM
    07txtaco
    07txtaco [OP] Member
    larry
    phx az
    07 dc taco 4x4
    Ok so i just switched from conventional oil to fully synthetic and my mpg dropped from 16.5 to 14. my miliage is at 40000 and i bought the truck at 36k so im thinking i need a tuneup but why such a big drop in mpg. also i read somewhere that pure acetone could help with mpg by up to 20% any thoughts.
  2. Sep 3, 2010 at 7:20 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    If pure acetone helped that much, everyone would be running it, like TB spacers or Fitch Fuel catalysts or Hydrogen generators......... Second, it would probably destroy the emissions components.
    Do a basic tune up; plugs, clean the MAF, air filter, yada yada yada. Then see what the MPG is.
    Just changing from dyno to synthetic is going to give you a noticable or significant increase anyway.
  3. Sep 3, 2010 at 7:21 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    That's weird if any thing it's suppose to improve MPG. Did you add any weight to the truck? Did you start driving faster? Did you use a heavier weight of oil? I thought about the acetone thing but instead I drive slower.
  4. Sep 3, 2010 at 7:25 AM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    maybe its opposite day?
  5. Sep 3, 2010 at 7:27 AM
    07txtaco
    larry
    phx az
    07 dc taco 4x4
    nope stayed at 5w 30. driving habits are the same. i wonder why i get crappy mpg though. i would be happy if i could just average 17
  6. Sep 3, 2010 at 7:28 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    :laugh:
  7. Sep 3, 2010 at 7:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Change the plugs. If the records dont indicate it was done at 30K, you need them changed.
  8. Sep 3, 2010 at 7:34 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Acetone?
    Does it go in the oil or in the gas???
    I have never heard of this, kind of scary to me.
  9. Sep 3, 2010 at 7:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It used to be used in Supercharged, or turbo'ed aplications mostly. Then, People became aware that its not a good idea, and started doing it the right way, and adding more fuel.
  10. Sep 3, 2010 at 7:42 AM
    07txtaco
    larry
    phx az
    07 dc taco 4x4
    it goes into the gas. from what ive read it said 2 oz for every 10 gallons of gas.. ok so besides the plugs should i change the wires as well or no. never really done a full tune up but i know how to change spark plugs
  11. Sep 3, 2010 at 7:43 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    DO NOT USE ACETONE IN YOUR FUEL!
    lol there's so much bad info out there on ways to improve MPG. I would go to your local parts store and get some lucas fuel treatment and dump that in there on your next fill up. I did it and it helped get me back up to 17mpg average.
  12. Sep 3, 2010 at 7:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just the plugs. Gap them at .041. First, Find out if they were even changed. If there is no doccumentation, pull a driver side plug. If its an NGK, more than likely, they havent been changed.
  13. Sep 3, 2010 at 7:50 AM
    07txtaco
    larry
    phx az
    07 dc taco 4x4
    ok lets say i change them for the hell of it what would be the best spark plug for better mpg. also is there a way to get into the computer with my scan gauge and mess with the engine so its at a lower rpm. right now at idel im at like 700
  14. Sep 3, 2010 at 7:50 AM
    Masada
    Taylor
    Laveen, AZ
  15. Sep 3, 2010 at 7:52 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    OEM Denso's give the best performance. No...You cant hack into the ECU to change the engine peramiters..
  16. Sep 3, 2010 at 8:00 AM
    07txtaco
    larry
    phx az
    07 dc taco 4x4
    ok so besides the plugs any other ideas. my k&n still looks cleans i oiled it up last oil change.3k miles ago
  17. Sep 3, 2010 at 8:05 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Clean your MAF sensor.
  18. Sep 3, 2010 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Clean your MAF, and dump the K&N filter for an OEM.
  19. Sep 3, 2010 at 8:08 AM
    OH-MAN
    Sunny Az.
    10 4X4 O.R. White
    Do the plugs, Make sure you did not over oil the K&N.
    As Chris said do not mess with the engine control computer stuff.
    There is no wonder MPG trick. If you check air pressure in tires to keep them up to proper anounts, control your foot, let off sooner as you approach stop signs and lights, run 65 instead of 75 on the freeways.
    Carry no more weight in the truck than you need and hope for a tail wind.
    Thats about it.
  20. Sep 3, 2010 at 8:13 AM
    07txtaco
    larry
    phx az
    07 dc taco 4x4
    thanks people hope yall have a great labor day weekend off to the part store.
