Why doesn't Toyota put a manual 4x4 lever in the Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SilverTacoZack, Aug 13, 2011.
  1. Aug 13, 2011 at 11:38 AM
    SilverTacoZack
    SilverTacoZack [OP] Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    The functionality is the same except you are relying on electronics rather than a mechanical device
    Varak likes this.
  2. Aug 13, 2011 at 11:40 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I have to disagree. My 91 4Runner had a manual lever TC, I loved it, you felt the gears engage and knew it was in 4hi. Both my Tahoe and Tacoma had/have the switch. I would like mechanical over electric any day.
    Yes, they both get you into 4wd, one you know your in, the other you have to trust the little dash light
  3. Aug 13, 2011 at 11:42 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Levers and manual hubs FTMFW.
  4. Aug 13, 2011 at 12:25 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
    Toyota didn't so I did with the help of Wyatt and Fire931......
    jeeps123 likes this.
  5. Aug 13, 2011 at 1:48 PM
    RogerRZ
    RogerRZ Well-Known Member
    New Brunswick, Canada
    White '14 DCLB TRD Sport
    I go out in the willywags every day, because it's my job. I put roughly 200 miles per day off road, and don't like to put it 4wd unless I have to (fuel mileage is bad enough in 2wd). If there is a hole I know I'll need 4wd in order to get through, I stay away from it, and get someone to fix the road. Like I said, 4wd is my "get out of jail free" card, if you will. My old Silverado would engage 4wd at a standstill, no questions, and IMO, that's a good thing. I don't think asking for this capability in a truck is too much.
    The last time I got stuck, the tow vehicle was yellow and weighed 25 tons...
  6. Aug 13, 2011 at 2:29 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    The new 4runner trail editions have them.
  7. Aug 13, 2011 at 2:51 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    The FJ is an off road vehicle... The Tacoma is MANY different vehicles: Base, SR-5, Sport, Off Road. 2WD and 4WD... most in 2WD. If they just had the manual lever shifter in the Off Road, then that may be another plus... but cost wise, it is probably silly not to have all the 4WD models share the same dial shifter? My 2001 Taco had the lever with a button... The button was for H4 and the lever was for L4... It was really an electric set up but made to look like a real direct lever... Being phoney, I am glad they dropped the pretend lever. I think Toyota should stick with real working stuff on the trucks and not use dress-up phoney stuff 'for looks'... But that is just my opinion. ;)
  8. Aug 13, 2011 at 5:41 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I've never had an issue shifting into or out of 4WD in my Tacoma, and I use 4WD on a weekly basis.
    Our Jeep would constantly pop in and out of 4HI. I'd adjust the lever mechanism, it would work fine for a while, and it would need adjustment again.
    When we had the Jeep shipped, they managed to bend the bar that leads between the cab and the transfer case.
    Just my experience.
  9. Aug 13, 2011 at 6:16 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Could not agree more. When we get lockers as the option instead of locker wannabe ATRAC ?:D
  10. Aug 13, 2011 at 11:10 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    I think David K nailed it.
  11. Aug 14, 2011 at 7:10 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    David K is right, I also don't want them to put a fake lever. What I was asking for is they go back to putting a real mechnically operated transfer case lever like the old trucks used to have. I think, at the very least, this should come on the TRD offroad. I also think towing package equipped Tacoma's should come with the TSB springs by default. And the Xrunner should come with the TRD supercharger. It just seems like the different configurations are a bit of a joke right now, except for the TRD offroad coming with the locker, that is the one thing they seemed to get right.
  12. Aug 14, 2011 at 12:16 PM
    Black07Taco
    Black07Taco Member
    Washington
    07 Access Cab 4x4
    I could definitely be wrong here, but I thought FJs (or at least some of them) have a "real time" 4wd system + the 4wd shift lever. So they auto kick into 4wd when needed using the real time while also giving you the option to use the lever and lock it into 4hi or 4lo.
  13. Aug 14, 2011 at 4:45 PM
    David K
    The OFF ROAD has the rear locker... and the A-TRAC improves upon the locker for traction by working the front and rear, but has NO affect on steering...
    YOU may not like it, but it does work and it is not phoney... Otherwise I would be right there with you on claiming the locker is the only way to go for true off roading. :D:cool:
  14. Aug 14, 2011 at 4:48 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I assume since toyota advertises the fj as an offroad truck and can go thru water,it's better for mechanical than electrical transfer case
  15. Aug 14, 2011 at 6:08 PM
    #35
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    The tacoma is also advertised as offroad. I mean, TRD offroad should actually mean something. I think that should mean getting the best offroad tech toyota has to offer on that package, otherwise dont sell it at all
  16. Aug 14, 2011 at 6:14 PM
    #36
    David K
    I agree, and my 2010 is the best of my 3 Off Road Tacomas!
    The dial shifter may be wimpy looking compared to the stick, but in over 132,000 miles on my two Tacos with the dial, they have never failed. It is quality and reliability that counts more than 'looks', IMO.
  17. Aug 14, 2011 at 6:30 PM
    #37
    Silver DC
    Silver DC Well-Known Member
    Mark
    Nashville
    07 TRD Prerunner SuperCharged
    Supercharged,TRD CAI, TRD exhaust, DTLT Headers, L.E.D. Taillights, Factory BHLM,Wet Okole Seat Covers,Weather Tech Digi-cut Floorliners
    On the new 4runners, the SR5 and Trail have the manual shift, and the Limited has the knob. I like the shifter better than the knob.
  18. Aug 14, 2011 at 6:47 PM
    #38
    n0rth
    J.W.
    New Mexico
    I know for me it was more about having 2 wheel low than the dial-a-drive setup when switching to a FJ case. I would also like to see manual hubs or at least not have the front CV's in motion constantly, Manual shift on the transfer case, lockers front and rear and a turbo diesel while I'm dreaming about it.
  19. Aug 14, 2011 at 9:26 PM
    #39
    BlueT
    NorthEast
    Yeah paper thin one that snaps in half like mofo
    http://www.tacomaterritory.com/forum/showthread.php?t=35345&page=10
    Only a genius would mate 8" elocker rear diff with 3.73 gears :rolleyes:
    I know I know when you hit gravel road it works. :D
    The only thing Atrac improves upon is bottom line of Toyota.. It costs pennies compare to locker to produce and if Toyota keeps Adverting some people will think its as good as lockers. Toyota sold you BS.
    Atrac was a failure when was introduced on Land Cruiser over 8 -9 years ago, and it is still failure today.
    I find it funny that you keep talking about how locker affects steering. Either you had never offroaded or you are simply ignorant. The very fact how affects steering is the principle what makes locker 1000 times better then ATRAC. Should have payed attention on Physics classes in school.
    ATRAC is like Yugo pickup. It is almost a real deal but it will never be as good as the real thing.
  20. Aug 14, 2011 at 9:29 PM
    #40
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Why isn't there a "manual 4wd locker"?
    Because it has an electronically actuated transfer case....
    Wording questions.... YAY!
