Why drum brakes on most of the Tacomas
Discussion in 'Technical Chat' started by dlopan, Oct 7, 2016.
  1. Oct 7, 2016 at 4:07 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You mean 4 pistons
    matt 157 likes this.
  2. Oct 7, 2016 at 4:14 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Probably closer to 70% with so little weight on the rear. Old technology that works just fine
  3. Oct 7, 2016 at 9:27 PM
    Claudiomartinof
    Claudiomartinof Well-Known Member
    2019 TRD OFF ROAD 6MT
    Yeah, 2 piston each side... for me it sound confusing when I read or see for example.. 6pistom on the front.. I imagine it better when I see one side only hahaha
    Different point of view I think...
  4. Oct 7, 2016 at 9:37 PM
    tacomatrd22
    tacomatrd22 TRD SuperCharged Tacoma
    Daniel
    Fort Smith, AR
    Supercharged tacoma
    FlowMaster Super 44 2" lift Gray wire Fog light
    Hope you know there was a test made with the 3rd gen Tacoma and the lastest version of the Colorado with braking. Guess which vehicle won, and it wasn't the Colorado. There's really not a big difference when it comes to stopping.
  5. Oct 8, 2016 at 2:33 AM
    dlopan
    dlopan [OP] Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    6 piston front brakes are on cars that cost a lot, Ferrari, lamborghini, those sort.
  6. Oct 8, 2016 at 3:23 AM
    Large
    Large Red
  7. Oct 8, 2016 at 5:44 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If you Don`t like Drum Brakes why did you buy a Tacoma ??
    Then maybe you never looked and figured they just had to have 4 wheel disc Brakes
    Myself I like Drum brakes Wheel cylinders and a Hardware kit and drums are much cheaper then Calipers and Rotors
    I enjoyed the days with Drum Brakes on the front axle
  8. Oct 8, 2016 at 7:27 AM
    dlopan
    Dave
    Albuquerque, NM
    Yes you are right. I didn't look but most if not all cars and trucks, semis, you name it except for tacos have disc brakes. I'm surprised the insurance companies and feds haven't screamed before now.
    Drums are cheaper, usually last longer. But if you want brakes that don't fade or freeze or not work at all in water. Discs are better.
  9. Oct 10, 2016 at 3:33 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    AFMurse2014 likes this.
  10. Oct 11, 2016 at 6:50 AM
    1Gunner
    1Gunner New Member
    in a van down by the river...
    silver
    Can't believe Tacomas still use drum brakes. Fred Flintstone would be proud...
    dlopan[OP] likes this.
  11. Oct 11, 2016 at 7:55 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Not any more...
  12. Oct 11, 2016 at 9:50 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Short lived temp ban. Gotta watch out for that ban hammer. Never know when or where it's going to strike lol
  13. Oct 11, 2016 at 10:02 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    All disk brakes have a drum brake inside for the parking brake so you do not escape the problem of dirt in the drum brake.
  14. Oct 11, 2016 at 11:24 AM
    worthywads
    Sometimes it is very predictable.
    Lawfarin[QUOTED] likes this.
  15. Oct 11, 2016 at 11:59 AM
    #35
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I can't say I know the main reason the drum brakes are on our trucks but I don't care. They work just fine and I'll get about 120K miles out them. I have a friend who's brother owns and operates a major semi truck brake shop. I've been the the shop many times and have seen the piles of used brake drums that are waiting for recycling. Drum brakes are used in semi's both in the tractor's rear axles and the trailer and they haul mega-tons of weight around. There has to be a reason that they do this and yet meet all the safety requirements of the trucking industry. From my simple physics point of view there is much more braking surface area in a drum brake than a disk. Disk brakes heat up much hotter but cools quicker since they are externally vented. Disk brakes have a much higher chance of warping the rotor than drum brakes on the drum. Semis can smoke the brakes down mountain passes but they'll run perfect after cooling. Consumer disk pads can separate if done often enough. Drum brakes are almost always dry, weight much less, has less of a chance on boiling the brake fluid, can be operated mechanically without hydraulics. Disk brakes are more responsive in perfect conditions.
    Like I said, I'm not that knowledgeable on brake types but I've always looked at it as an advantage. In a sports car I'd have disk on all corners. In a truck I think there isn't as much value for rear disk. I have 2 different braking systems to leverage the pros and cons of both systems.
    :crapstorm:
  16. Oct 12, 2016 at 6:25 AM
    #36
    tgear.shead
    tgear.shead Well-Known Member
    Uh, well actually, drum brakes weight CONSIDERABLY MORE than disk brakes. Aside from that, all good.
  17. Oct 12, 2016 at 7:52 AM
    #37
    knayrb
    Bryan
    Pure stock
    I don't know about that. I haven't weighed both on our trucks but I have taken both the disk and the drum off. I would say they are close in weight. Now I do know that the caliper and pads of the disk weight more than the slave piston, pads, springs, star gear, etc. From my elementary reading on the internet drums are usually assumed to weigh less. The disk brake also has a constant drag since they are not pulled away from the disk when not in use. The drum does pull away but that means it isn't as responsive as the disk. I'm not saying that the drum is better. I think a disk is better but in the Tacoma's application the drum brake gets the job done and it doesn't bother me at all that we have them.
  18. Oct 12, 2016 at 8:01 AM
    #38
    tgear.shead
    You can't say that one is "better" than the other, rather that each is best suited to the proper application.
    You are also failing to consider that most of the braking force is applied by the front brake, which means that the rear brake isn't as big as it would be if it were to be mounted on the front. So pick a drum brake that can supply the braking force of the front brakes, and compare THAT brake's weight to the front disk brakes!
  19. Oct 12, 2016 at 9:18 AM
    #39
    knayrb
    Bryan
    Pure stock
    I actually think we agree. The drum brakes in our truck are suited for the application. The OP's first statement on this thread was calling drum brakes stupid. I disagree that they are stupid. They work just fine for the application they are needed since 70-90% of the stopping force is on the disk brakes in front.
  20. Oct 12, 2016 at 9:42 AM
    #40
    nuphysalis
    nuphysalis New Member
    TJ
    Drum brakes are inexpensive, and when companies are trying to reduce cost to maximize margins, they look to reduce costs where ever they can. With most of the braking force coming from the front of the vehicle, rear braking force is not as high or crucial.
