Why is 2nd round of head bolt torquing spec-d in angles and not ft/lbs ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foampile, Aug 7, 2015.
  1. Aug 7, 2015 at 8:12 AM
    foampile
    foampile [OP] Well-Known Member
    Mid-Atlantic
    2007 V6 4WD 6 speed Extended Cab
    The spec says torque cylinder head bolts in a specific order first to 27 ft/lbs and then turn each in the same order another 180 degrees.
    Why did they spec the second round in degrees and not ft/lbs? Since I do not have an angle gauge, can anyone approximate what that 180 degrees on top of 27 ft/lbs would convert to in ft/lbs ... a ballpark ?
  2. Aug 7, 2015 at 8:17 AM
    foampile
    Mid-Atlantic
    No because it is set deep inside the head and also it is black so marking is kindof inconvenient
  3. Aug 7, 2015 at 8:18 AM
    Clearwater Bill
    Billy
    Largo Florida
    180* is half a turn.
    Don't worry about the ft# reading. Just follow the instructions.
  4. Aug 7, 2015 at 8:19 AM
    foampile
    Mid-Atlantic
    I understand that it is half turn but how do you measure that you went half turn when each pull you are moving rotationally only maybe 10-15 deg and that is not precise otherwise you could count ? keep in mind, the bolts are already on high torque, I can't just take a breaker bar and spin it freely 180...
  5. Aug 7, 2015 at 8:24 AM
    Clearwater Bill
    Billy
    Largo Florida
    27# is not high torque. You do lug nuts at 80 or 90, right?
    Anyway, since you are not getting a reading, you actually can use a breaker bar.
    Why not mark what you can see, which could even be where your extension fits the ratchet. Use that to eyeball your 180.
  6. Aug 7, 2015 at 8:26 AM
    foampile
    Mid-Atlantic
    I was thinking the same but it's kindof inconvenient because the bolts are set so deep inside the heads. There is also this tool.
  7. Aug 7, 2015 at 8:31 AM
    Clearwater Bill
    Billy
    Largo Florida
  8. Aug 7, 2015 at 8:34 AM
    foampile
    Mid-Atlantic
    I can only hope they will have it at Autozone so I can proceed with the job as opposed to having to order and wait for delivery ...
  9. Aug 7, 2015 at 8:37 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Sounds like your rebuild is coming along nicely.
    foampile[OP] likes this.
  10. Aug 7, 2015 at 8:39 AM
    foampile
    Mid-Atlantic
    Yes, I hope so. I cleaned the heads really nicely, cleaned the valves and lapped them. etc. but it's still too early to celebrate
  11. Aug 7, 2015 at 9:23 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    only 27ft lbs + 180 * thats all the head bolts need? hmm might double check that.
    Either way. Torque down to 27. Then mark the socket extension with a line, and do a 180... easy peasy.
  12. Aug 7, 2015 at 9:30 AM
    foampile
    Mid-Atlantic
  13. Aug 7, 2015 at 1:01 PM
    nd4spdbh
    SoCal
    interesting. I have never seen something like that before. I wonder what the final average torque is after 27 +180*
    Couple of the motors i have done head bolts have been up around 120ish ftlbs!
    I wonder for those fellows that have headgasket issues down the line... would torquing the head bolts down a lil more of helped?
  14. Aug 7, 2015 at 1:03 PM
    foampile
    Mid-Atlantic
    That was part of my question, to approximate an apples-to-apples comparison and avoid acquiring the angle gauge.
  15. Aug 7, 2015 at 1:07 PM
    nd4spdbh
    SoCal
    you wouldnt need an angle gauge. Like stated simply mark the socket extension with a line, note where it lines up with something on the head, and keep ratcheting untill its spun 180*
    foampile[QUOTED][OP] likes this.
  16. Aug 7, 2015 at 1:13 PM
    foampile
    Mid-Atlantic
    Thanks. I will try that.
  17. Aug 7, 2015 at 1:42 PM
    Toyko Joe
    Toyko Joe Here for the pictures
    I hope you're doing all the bolts on the head at 27lbs according to the tightening order, then on the second trip around doing the 180 degrees.
  18. Aug 7, 2015 at 1:44 PM
    foampile
    Mid-Atlantic
    Yes, that is exactly how I am doing it. I think I made that clear in the OP when I said "and then turn each in the same order another 180 degrees"
  19. Aug 7, 2015 at 1:51 PM
    Toyko Joe
    I got confused by your lack of commas if you completed the first pattern before starting the second round of tightening. My bad.
  20. Aug 7, 2015 at 6:50 PM
    adamax
    adamax Well-Known Member
    adam
    springville ut
    2015 trd off road
    You go the 180 deg to finish streching the bolt, these are torque to yield bolts and can only be used once.
    Blkvoodoo likes this.
