Why is my speedometer not accurate?
Discussion in 'Technical Chat' started by Claudio D, Jun 29, 2010.
  1. Jun 29, 2010 at 9:29 PM
    Claudio D
    Claudio D [OP] Member
    saugus mass
    09 4x4 2.7
    rubber bed mat undercover tonneau hitch step-bumper protector
    About 2 weeks ago I finally bought a nice GPS. Anyways its showing me that my speedo is reading 5-6 mph over. I do not like that at all. Is it possible to adjust the speedo? Also how is it done and what will it cost to correct it? Or are they all this way? Also my tacoma is stock tires not worn.
  2. Jun 29, 2010 at 9:44 PM
    Brunes
    Brunes abides.
    Rotorhead
    Due to the inaccuracy of converting a digital signal to an analog needle. Use a ODBII tool (like a scan gauge) and see what the digital read out is for your speed...then make a decision from there.
    There are calibrator tools out there...but some folks had had errors pop up from them time to time.
  3. Jun 29, 2010 at 9:45 PM
    747 function > form
    1st Gen.
    Mine is the same way...I rely on the GPS for an accurate read...tire size could also have something to do w/it [maybe].
  4. Jun 29, 2010 at 10:11 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I think tire size is the main factor. I have a TRD Sport and it's only reading 3mph over confirmed with GPS and driving by one of those police "your speed is" get ups. The larger tires on mine mean that the speedo will be closer to right. People with slightly larger tires than the ones I have seem to be right on the money with accuracy.
    I actually like that mine is a bit over. Keeps me out of trouble.
  5. Jun 29, 2010 at 10:25 PM
    SilverMac
    SilverMac Mine's the silver one...
    Keller, TX
    2008 PreRunner DC SR5
    Mine was the same way until I got 265s. Now it's dead on. Since your speedo is reading fast, wouldn't it be safe to asume that the odometer is also turning too fast? In other words, you've got more miles showing on your truck than you've actually driven...
  6. Jun 29, 2010 at 10:35 PM
    Claudio D
    saugus mass
    09 4x4 2.7
    Thanks for the replys. When the time comes I will up size the tires to 265 but I got a 4cyl will I lose much low end power? Should I ask the dealership to recalibrate the speedo? Im not happy about the inaccuracy! On my Suzuki GSXR its just a part you plug in "speedo healer" it was also about 5mph off.
  7. Jun 29, 2010 at 10:38 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Yup, as far as I know. And if you really want to give yourself an aneurysm do the math. It's actually a significant amount. Up close to 100k miles it's over 8k miles I believe. Your calculation will also depend heavily on what you use for your "average" speed that you think the truck will see.
  8. Jun 30, 2010 at 1:29 AM
    JKD
    JKD Well-Known Member
    On most vehicles I have noticed that the speed the computer actually sees--and the one that is used to compute the odometer reading--agrees with GPS speed very closely. It's the speedometer needle that is off.
  9. Jun 30, 2010 at 1:34 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Mine is the same way but that was after adding 33" tires. I honestly think yours needs adjustment.:eek:
  10. Jun 30, 2010 at 2:14 AM
    maxboostcore
    maxboostcore Well-Known Member
    SOCAL
    09 Tacoma
    My Tacoma speedometer is 2 mph difference to my gps but my integra speedometer matches with my gps speed fine. I was wondering that too because I would like it to match with my gps.
  11. Aug 11, 2010 at 7:34 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    I complained about this back in 2006 while under warranty. They ran tests and said it was within spec...something like it can be 10% off at 60 mph...~5-6mph off. Sucks but I think that's the way it is...calibrations is expensive.
  12. Aug 11, 2010 at 8:06 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    It's as much a legal as a technical issue ... Toyota (like many other manufacturers) spec's the speedometer's allowable variance so it reads on the 'fast' side. If they allowed it to read 'slow' they could be liable for tricking you into speeding.
  13. Aug 11, 2010 at 8:24 PM
    larryde09
    Larry
    Rochester, NY
    Maybe we should start a class-action suit since our odometers might be off. Although I read another thread that said a scangauge read the speed correctly, so there's something fishy going on between the input and the actual gauge reading.
  14. Aug 11, 2010 at 11:43 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    There's no reason to do that. It is defined by both UN and US federal laws the amount allowed to be off. Pretty senseless to sue a company for following the law.
  15. Aug 12, 2010 at 5:15 AM
    larryde09
    Larry
    Rochester, NY
    Sorry, I should have put a smiley face...I was (somewhat) kidding. This reminded me of a recent class action with a similar issue...where speed-o's forced odometers to be off...everyone was granted an extended warranty to compensate, among other specific damages for improper warranty coverage, lost value of vehicle, etc.
  16. Aug 12, 2010 at 10:36 AM
    JKD
    On another car forum, people were discussing how to 'correct' the speedometer for a variety of reasons. People would disassemble the gauge cluster, remove the clear plastic gauge cover, and then get on the highway with some way to monitor speed (one guy had a cop friend with a calibrated speedometer pace him, others used GPS or OBD-2 scanners). They'd confirm their speed at 60 or 70 mph, and then install the needle (or have a passenger do so to be safe!).
    If you're that concerned about it being off a little bit, you could probably figure out a way to do that with your Tacoma.
  17. Aug 12, 2010 at 1:15 PM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    With regard to manufacturing, speedometers are certified by manufacturers to follow EITHER the U.S. SAE (Society of Automotive Engineers) J1226 OR the European version, ECR-39. The SAE rule, published in 1983, allows readings to be plus or minus 2 percent of true speed, or on a sliding scale from minus 1 percent to as much as plus 4 percent :D
  18. Aug 12, 2010 at 1:17 PM
    ::childstoy::
    ::childstoy:: Hi-Tech Rednek
    Southeast, PA
    Black 2010 TRD Sport
    TRD Exhaust, Tint, Stubby Ant., Debadged, Weathertech Mats, Grillcraft... Currently collecting donations for a New Tires Fund.
    Same here... Like 4-5 mph off.
  19. Aug 12, 2010 at 1:33 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    im about 5mph slow on my speedo , hoping that it will be correct once i step to 285's
  20. Aug 12, 2010 at 2:02 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    Changing my 5 lug's 215-70s to 235-70s brought my GPS and speedometer into agreement. It was off by about 4-5% before that.
