Why is my speedometer not accurate?
Discussion in 'Technical Chat' started by Claudio D, Jun 29, 2010.
  1. Aug 13, 2010 at 2:15 PM
    ROCKSLINGER
    ROCKSLINGER Zombie Response Team
    Robert
    Reno Nv
    14 MGM DBL CAB 6 SPEED
    Fox Coilover with reservoir, Fox Remote Rear reservoir, Wheeler's 3 pack AAL, Grillcraft Grille color matched, Rampage 50" LED Light Bar, Relentless 1/4" IFS-Mid and Transfer case Skids, Relentless High Clearance Rear Bumper, Kenwood 1800 watt Amp, 12" Rockford Fosgate P3 Shallow Sub, 1 Farad Capacitor, Redline Hood Struts, Weathertech Floor Mats, Doug Thorley Long Tube Headers, Flowmaster Delta 40, URD MAF Calibrator, URD Short Shifter, CST Black Leather W/Red Stich, On Board Air, Train Horns,
    I have the hypertech speedometer recalibrater installed in my truck. Seems to work. But I have a bigger issue with mine where it will be off by as much as 10 mph sometimes and other times be dead on according to the gps. That seems to mostly happen when I'm putting my foot into it. If I'm spinning my tires or doing donuts in the snow sometimes it will say I'm doing 15 mph when I'm stopped and will continue to be off by 15 mph till I shut it off and let it rest. Any ideas on that?
  2. Aug 16, 2010 at 6:37 AM
    cinch
    cinch Member Extraordinaire
    Al
    Boulder Creek Ca
    2010 Prerunner double cab
    If you are spinning your tires or doing donuts then your wheels and drivetrain are turning even if you're not moving and the speedo is sensing the drivetraing turning.
  3. Aug 16, 2010 at 6:44 AM
    chaztoyo
    chaztoyo Well-Known Member
    Chaz
    West TN
    10 Tacoma DCSB TRD Sport White
    I just checked mine this weekend with a gps, and at 60 indicated I was actually going 58 per the gps. I can live with the 2 mph difference, especially since the speedo is reading fast. This is in a 2010 TRD sport, so it has the 17 in wheels. If it was off by 5 or 6, that would be a little too much.
  4. Aug 16, 2010 at 8:26 AM
    tig1
    tig1 Well-Known Member
    Paul
    Saint John,New Brunswick,Canada
    2009 tacoma
    n fabs,window visor tonneau ,bilstein 5100's all round.245/75R16Toyo A/T II
    I have a 2009 Taco,access cab an when I was going down the road the police have a portable radar that tells you your speed. I held my truck at 65 kms and the radar read 62 kms.
    later tig1
  5. Aug 16, 2010 at 8:41 AM
    ROCKSLINGER
    Robert
    Reno Nv
    Yes I realize that. But it even happens when im not spinning out.
  6. Sep 10, 2010 at 12:28 PM
    Tugger161
    Tugger161 New Member
    Bill
    Homosassa, Fl
    2011 SR5 2wd 6cyl Pre-Runner
    2011 Tacoma dbl cab gps 62 speedo 65. Dealer says this is normal on all Toyota's. Frist car-truck i had that did not match gps. Stock 16" Tires
  7. Sep 10, 2010 at 5:04 PM
    Barnone
    Barnone Guest
    That's what I plan to do next time I need tires so it good to know that the 215 to 235 will correct the error since I am also 5% low on my odometer/speedometer.
  8. Nov 13, 2011 at 9:23 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm bringing this back. After getting my Duratracs put on a few months ago I'm consistently getting shitty mileage now. I don't have a lift so mine are the largest you can put on the stock ride height, nothing extreme. My speedometer reads DEAD ON now that I have the larger tires. I'm also getting roughly 300miles to a tank now and about 3-4mpg less than before. My mileage readings have been quite consistent regardless of how much I focus on driving conservatively.
    This confirms that larger tires on your truck will in fact slow down the rate at which your odometer reads miles.
  9. Nov 13, 2011 at 2:03 PM
    Quo Fan
    Quo Fan Well-Known Member
    Paul
    Southwest Virginia
    2017 Barcelona Red TRD Off-Road
    Nerf bars
    My speedo on my '08 Access Cab reads 70 when my GPS says 65. I know the variation, and just cruise along at "70".
  10. Nov 14, 2011 at 11:05 AM
    ruger1
    ruger1 Active Member
    Western NY
    2011 TRD OFFROAD
    rear tsb, bilstein 5100's all around, trd exhaust.
    My mileage went to shit when i installed my duratracs also. I went from 18-18.5 MPG to 16 MPG now. I never checked my speedometer before i installed them. Will try it today.
  11. Nov 16, 2011 at 8:11 AM
    ruger1
    Western NY
    2011 TRD OFFROAD
    I just checked my odometer against a gps and my odometer is dead on now with my 265/75-16 duratracs installed. I guess my MPG's now are acccurate compared to before.
  12. Nov 16, 2011 at 8:45 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    I have been getting these exact results with the same size Duratracs. I thought the tread pattern was killing mileage. I didn't think that it's actually more accurate now.
    PS some of you guys are thinking tire width will fix the speedo (the higher number: 2XX). Its the combination of the wheel size, width, and ratio that give you diameter.
  13. Nov 16, 2011 at 8:52 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Here is where it gets contradictory & bizarre.......265/70/16s, GPS says 70 and speedo says 67-68 BUT........the odo/trip matches the mile markers exactly on different frwys for 10-15 mile spans around town. I have done this on 4-5 interstate & state hwys around my area with same results. I mean they are never more than a tenth +/- off from mile to mile and avg out dead on for total distance. WTF do you adjust? I'm OK with the speedo being in my favor a couple or few mph for not getting a ticket & as long as the odo/trip are correct then my mpg calculations are correct. Just weird shit that speedo can be off a few but odo isn't. Seems both would be affected like in my old truck that had mechanical vs. electronic speedo/odo.
