Why no titanium skids?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sea_ledford, Nov 1, 2018.
  1. Nov 1, 2018 at 5:58 PM
    sea_ledford
    sea_ledford [OP] Active Member
    2018 DCLB OR Cement
    peeled off the dealer sticker
    I just saw the video on the new AEV hot stamped boron steel armor for the ZR2 Bison. Looks like awesome stuff for weight limited mid-sized trucks. It also looks like it will cost a fortune to produce.
    It got me wondering why there aren't titanium options in addition to steel and aluminum for skid plates, or even bumpers. Sure it'll be more expensive than either, but it is 40% lighter than steel for 95% of the strength. It can be welded rather than needing to be stamped like the boron steel.
    I'd love some armor, but not digging the 800-1000 lbs of weight it'll add.
    Is it too flexy? To hard to weld? There has to be some reason aside from cost. Lord knows we spend some stupid amount of money for truck whosi-whatsits.
    -Chris
  2. Nov 1, 2018 at 6:01 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    I married my tacoma likes this.
  3. Nov 1, 2018 at 6:02 PM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    I think it’s just the money aspect and in turn, there wouldn’t be a market. Steel skids are what, $250 for each skid (ifs, mid, transfer case, gas tank). That’s already $1k. I’m guessing these would easily be double that price for just skids. Then these winch bumpers with hoops are $1500. Double that and then double a $1500 rear and you’re gonna be bumping up close to the $10k range in just armor, no suspension or anything.
    Disclaimer: I don’t know the price of titanium. This is a pure guess
    SR-71A and Skierrichy like this.
  4. Nov 1, 2018 at 6:03 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It’s likely exclusively cost. Titanium is 25-50x more expensive than steel and aluminum. So you are looking at several thousand in material alone.
    300 pounds in steel skid plates has the same strength as around 150 pounds of titanium. Titanium sells for around $25 dollars a pound according to google so a simply set of skids casts $3750 in material alone
  5. Nov 1, 2018 at 6:03 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The hardness makes it harder to work with. Titanium chews up tooling quick.
    Skierrichy, Simpleton and Gunshot-6A like this.
  6. Nov 1, 2018 at 6:05 PM
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    In my experience working and manufacturing around titanium, the biggest factor is cost. It’s not negligible, and gets significantly more expensive depending on the size of the plate. You’re talking a minimum of 5 to 10 times the cost just in raw materials.
    Next, you have the manufacturability. All the drills used for stainless applications are useless in Ti, and HSS tooling burns out quick. Carbide and non-clapped out mills are a damn near must. It’s much easier from a tooling standpoint to only do steel alloys and aluminum.
    Finally the fabrication standpoint. Titanium does not take a bend or form well, and from my understanding is near impossible to weld.
    The weight savings you’re looking for would result in probably over 10x the price tag as comparable skids on the market.
  7. Nov 1, 2018 at 6:07 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Carbon steel is about $.50 per pound, aluminum is about $1.75 and titanium is about $25. Of course they aren’t the same density but that should give you a relative idea.
    shakerhood likes this.
  8. Nov 1, 2018 at 6:07 PM
    hoarder23
    Shay
    NJ
    Scratches
    Also as previous posters have noted, cost. A 3/16" 3'x4' plate costs over $2k, the same size aluminum plate is less than $300. And that won't even make an IFS skid.
    beergeek and mateo_roberto like this.
  9. Nov 1, 2018 at 6:10 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  10. Nov 1, 2018 at 6:17 PM
    sea_ledford
    2018 DCLB OR Cement
    So if I had won that $1.5 Billion lottery I could have some? :)
    I didn't realize ti was THAT much more expensive. I am a diver and there are a lot of Ti parts available that have maybe a 25% premium on them, not a x25 premium!
    I figured the tooling difficulty would be the primary driver.
    -Chris
  11. Nov 1, 2018 at 6:39 PM
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    Fuck titanium. Not as strong as 4130 and not as light as aluminum. If you need something light, engineer it right, out of aluminum. If you need something strong, engineer it right, out of chromoly.
  12. Nov 1, 2018 at 6:43 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    In terms of specific strength titanium is pound for pound better than aluminum. So can be made lighter than aluminum in design.
    https://en.m.wikipedia.org/wiki/Specific_strength
    Skydvrr and Skierrichy like this.
  13. Nov 1, 2018 at 6:43 PM
    stun gun
    Aaronski
    Tacomas.
    I apologize for being short. It’s just... I knew this article was inbound. My advice to anyone seeking titanium anything on large components (bikes and trucks) is going to be disappointed. Which is why these things are rarely fabbed because titanium has no real advantage in these applications, except for hype to the unaware.
    Op wants 40% lighter than steel at 95% of the strength (lol) ok. Do carbon fiber then. Carbon fiber has impressive numbers as well. But like titanium, it doesn’t have the properties of, say, 4130 chromoly that’s been heat treated. It won’t flex, it’ll snap. It’s dog shit when dealing with impacts, like when you’re coming down on a rock.
  14. Nov 1, 2018 at 6:56 PM
    ZYBORG
    ZYBORG Let's roll...
    TX / S. FL
    3G TRD OR
    Why not gold???
    Stocklocker likes this.
  15. Nov 1, 2018 at 6:56 PM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    No worries. I think we agree that it makes no sense in these applications.
    stun gun[QUOTED] likes this.
  16. Nov 1, 2018 at 7:10 PM
    disk_55FL
    disk_55FL Well-Known Member
    disk
    Buckeye
    '17 TRD Sport MT
    Ti 6-4 which is the most common type ..... is considerably stronger than 4130.
    It is very easy to weld with GTAW ...... if you're building sliders ..... an not a space ship.
    Think real Armor ( Military )
    AISI 4130 Steel, normalized at 870°C (1600°F)
    Physical Properties
    Metric
    English
    Tensile Strength
    435 MPa
    63100 psi
    Elongation at Break
    25.5 %
    25.5 %
    Reduction of Area
    60 %
    60 %
    Modulus of Elasticity
    205 GPa
    29700 ksi
    Titanium Ti-6Al-4V (Grade 5), Annealed
    Physical Properties
    Metric
    English
    Tensile Strength, Ultimate
    950 MPa
    138000 psi <--
    Tensile Strength
    880 MPa
    128000 psi
    Elongation at Break
    14 %
    14 %
    Reduction of Area
    36 %
    36 %
    michael roberts and DaveInDenver like this.
  17. Nov 1, 2018 at 7:12 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    There's a way to weld it..its not cheap or easy or fast.
  18. Nov 1, 2018 at 7:14 PM
    Ensemble88
    Ensemble88 Well-Known Member
    San Diego, CA
    2017 Black OR DCLB
    King suspension, SSO bumper w/winch, Pelfreybuilt sliders, morimoto fogs
    Solid info, I had been wondering the same thing as OP. I'm not a fabber or anything though, thanks for the info guys.
  19. Nov 1, 2018 at 7:15 PM
    disk_55FL
    disk
    Buckeye
    '17 TRD Sport MT
    Sure it's easy to weld ...... if you have TIG ...... just change the filler ...... 100% Arg. is fine.
    This would work for sliders ...... not space ships.
    95 taco and lucky13don[QUOTED] like this.
  20. Nov 1, 2018 at 7:17 PM
    stun gun
    Aaronski
    Tacomas.
    These titanium vs whatever numbers always come up when this topic comes up. I don’t have the energy to source and argue, so I won’t. Frames, cages, sliders... have abandoned this material because while the final product can be lighter and stiffer, it needs to flex, and instead ALWAYS snaps.
    12TRDTacoma and m603holden like this.
