Why sway bar?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCFirefighter, Jul 1, 2010.
  1. Jul 1, 2010 at 3:39 PM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    It was suggested to me today, during a front lift install, to leave the sway bar off. Having very little automotive engineering knowledge, why?
    What are the pros and cons?
  2. Jul 1, 2010 at 3:43 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    you'll have better articulation, but it'll ride different you would have to get used to it
  3. Jul 1, 2010 at 3:45 PM
    SCFirefighter
    Stephan
    Cary, NC
    ENGLISH please! .. lol
    My car can't speak, so what kind of articulation are you talking about?
  4. Jul 1, 2010 at 3:48 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I personally - would not recommend removing it or disconnecting it for driving on the street. It's there for a reason and if you ever get into a panic situation and have to swerve quickly, having that sway bar intact could keep all 4 wheels on the ground.
    In that same situation - without a sway bar - could cause a roll-over.
    If you do any offroading - you can disconnect it for offroading as it allows the suspension to move more freely. Re-connect it for your drive home.
  5. Jul 1, 2010 at 3:50 PM
    PLC721
    Patrick
    Chandler, Az
    see how his pass tire is higher than his driver...articulation
  6. Jul 1, 2010 at 3:51 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Pro: More wheel travel (articulation).
    Con: Less stability on the pavement, increased chance of a roll over.
    I do not have my sway bar on my truck. It feels perfectly safe on the street, although it does like to lean a little in corners. What coil overs (shocks/springs) you're running up front will come into play in how the vehicle feels.
    If you don't know what it is or what it does, you're probably not ready to take it off. When you need more wheel articulation, you'll know it.
  7. Jul 1, 2010 at 4:00 PM
    SCFirefighter
    Stephan
    Cary, NC
    I love to see the flexing. Didn't realize that was related to the sway bar. Thanks for elaborating guys. I'll try it sometime just to see how it feels.
  8. Jul 1, 2010 at 4:11 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    I had my sway bar removed when I was running Icon coilovers. Truck drove nice with not much body roll. Then when I switched to Bilstein 5100, I noticed a lot more roll and lean in the corners. I reinstalled the sway bar and the truck handles great now. I actually prefer it on now.
  9. Jul 1, 2010 at 4:46 PM
    SCFirefighter
    Stephan
    Cary, NC
    I just installed 5100's and ToyTec coilovers. Like I said, I might give it a try sometime soon.
  10. Jul 1, 2010 at 5:00 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I would keep it on for street driving and remove if you need to on the trails. I have quick release swaybar on my JGC so it takes me a minute to go from having to not having. Best of both worlds.
  11. Jul 1, 2010 at 5:10 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I removed mine with the 5100 install. There is a bit more roll, but the increased performance is totally worth it when you drive on rough dirt roads everyday.
  12. Jul 1, 2010 at 5:25 PM
    SCFirefighter
    Stephan
    Cary, NC
    I could just disconnect the links right? Removing and re-installing the bar just for on/off road is too much work
  13. Jul 1, 2010 at 5:46 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    Wouldn't you have to fully remove the bar? Just disconnecting the links will make them flop around. Wish we had a quick release and something to latch it on to.
  14. Jul 1, 2010 at 5:48 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
  15. Jul 1, 2010 at 6:07 PM
    SCFirefighter
    Stephan
    Cary, NC
  16. Jul 1, 2010 at 6:10 PM
    08pretaco
    Oliver
    az
  17. Jul 1, 2010 at 6:18 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Bay Area, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, 255/754R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    I pulled mine off this past weekend and I honestly haven't noticed any difference in body lean and I take corners fairly hard, albeit not as hard as I did with it on just to be on the safe side. You can take it off and drive around town a bit to see how it feels, like others have said your suspension setup will affect how it feels too. If you have brand new springs it'll probably be pretty firm with or without the sway bar depending on the spring rate.
  18. Jul 1, 2010 at 6:28 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    taking mine off by this weekend..got the OME lift
  19. Jul 1, 2010 at 8:04 PM
    Janster
    Jandy
    Lancaster, PA
    Research online about 'Quick disconnects' - there are writeups on how to make your own quick disconnects. I had a set on my 96 that I bought from someone else who made the kits (he doesn't make them anymore).
  20. Jul 1, 2010 at 8:09 PM
    wlmuncy
    William
    Knoxville, TN
    With quick disconnects you should not have to remove it, just disconnect it and go. You might have to tie it up to keep from loosing it, but that is not a big deal.
