Why would Toyota do this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PropJet, Oct 7, 2009.
  1. Oct 7, 2009 at 9:37 AM
    PropJet
    PropJet [OP] Well-Known Member
    KS
    '09 DC TRD Off Road
    ToyTec Ultimate Lift Kit, Moto Metal 955's, GoodYear DuraTrac 265/75/16's, N-Fab Nerf Bar
    Due to having hurt my back a few days ago, I decided to let the local service shop install my new uca's. I got a call from them a few moments ago advising me of a problem. As explained to me, the bolts holding the stock uca's on the truck are installed backwards. I have two options... they can hack up the wheel well fender liner in order to get them out, or they can cut the bolt and put new ones in. I told them to cut it out, as that would be the cleanest install. Unfortunately, the local Toyota dealer does not have any of the bolts in stock, so they are going to have to be ordered from Kansas City. I am still waiting to hear back as to when they will be in. The end result is that I don't know when my truck will be done, I don't want to drive it in the meantime due to needing an alignment, and I will have an additional $66 in parts due to having to cut out the old bolts.
    Does Toyota intentionally install the bolts backwards, or had the installer been drinking the day my truck was on the assembly line?
  2. Oct 7, 2009 at 9:42 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Actually in order to remove that bolt the inner fender does have to be bent out a little. Its typical with the installation of aftermarket UCA's. Maybe Chris4x4 will chime in shortly.
  3. Oct 7, 2009 at 9:46 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    It takes a little bending of the fenderwell to get that bolt out anyway. I don't think it is installed backwards at all. Read this install thread, and it states about bending the fenderwell, then installing the bolt the opposite way, because it is much easier to put in. I can't imagine a toyota tech doesn't know that the bolt goes in that way and it is a bear to get out. Read this thread I think it will answer a lot of questions...heck send it to the mechanic. The bolt also looks like it could be picked up about anywhere.
    http://www.tacomaworld.com/forum/suspension/14507-total-chaos-uca-how-install.html
  4. Oct 7, 2009 at 10:15 AM
    PropJet
    KS
    '09 DC TRD Off Road
    I'm at a little bit of a disadvantage here because I'm out of town, and my truck is at the shop, so I don't have anything to look at. I called the shop back and explained that others were able to bend the fender, and the owner (who is a family friend, so I trust him) said that he would still recommend cutting it out and replacing it for two reasons. First of all, it would cost me more in labor charges for him to bend it, than it would to just replace the bolts. Secondly, he indicated that alll that bending would flex / crack the paint, and I would likely have rust issues later down the road. For what it's worth, he also said the the instructions even said to cut it out. Additionally, I asked if the bolt were some kind of generic bolt, and he indicated no, that it is about 12-13" long.
    Are you guys and the owner talking the same thing, or is he referring to something else?
  5. Oct 7, 2009 at 10:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like they dont know what they are doing. Any toyota dealer should be able to take thos bolts out in no time. They can be taken out, with a 1/2" bend to the pinch weld on the inner fender, OR, the body can be jacked off the frame 1" to get clearance, OR, they can cut the head off the bolt, and replace with a new one. Sounds like they are just idiots.
  6. Oct 7, 2009 at 10:19 AM
    98tacoma27
    Ben
    Not Beech Creek
  7. Oct 7, 2009 at 10:22 AM
    hendooman
    Jeff
    KC
    if you look at that thread it shows that Chris4x4 bent the inner fender to get the bolt out. Knowing the things he does and all the install threads he has provided, I don't think he would bend it if he thought it would cause damage later down the line. If he already cut the bolt it is a mute point. But if not and you want your truck back fast, I would have him bend it...it is a slight bend that is needed. You can bend it with channel locks, I am not sure how they would charge more labor for that? Once you go to install the new UCA's you flip the bolt around and come the other way to make it easier.
  8. Oct 7, 2009 at 10:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. Any of the bending I have done, hasnt done more than a little chipping of the paint. Which is not visible, as the fender liner covers it up. If you live in a high rust area, you can spray a little paint on it. Also, I havent seen any of the pinch welds fail doing this.
  9. Oct 7, 2009 at 10:25 AM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    It is entirely likely that the UCAs were installed before the fenders were installed, where that direction of the bolts makes sense.
  10. Oct 7, 2009 at 10:28 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    X2349864039860876
    just bend the metal, the paint didnt crack on mine and if you move things out of the way (brake lines, etc..) you really don't have to bend it that much. and on assembly my bolts are facing the opposite way they were originally installed, a year later and they have never been loose or had any problems. send the mechanic the write up on changing UCA's.
  11. Oct 7, 2009 at 10:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    x2. Body mounted to completed chasis
  12. Oct 7, 2009 at 11:32 AM
    Canadianboy
    Canadianboy Taco love in East Van
    James
    Vancouver, BC
    09 TRD Sport S/B 4x4 Auto in Mag Grey
    Icon Stage 3, Goodyear Duratracs and KMC Addicts!
    The bending is really easy!!!! All they have to do is take a pair of vise grips and bend the fender outwards and the bolt will slide out. Its really, really easy!!! Not difficult at all. Also, the bolts are installed like that for a reason. If the nut ever came off, the bolt will stay in place due to gravity. The other way around and the bolt would fall out, and the uca would fall off and you'd have a huge accident if you were going 100 on the interstate.
    Tell them to use a pair of vise grips and bend the bender a bit, its really not that difficult. It took me about 5 minutes per side to do.
  13. Oct 7, 2009 at 11:41 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
