Wierd A/C noises??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06rubi, Jun 17, 2010.
  1. Jun 17, 2010 at 11:56 PM
    06rubi
    06rubi [OP] Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Does anybody's A/C (v6) make a clunking grinding'ish noise when the compresser engages? Just want to see if its normal or if I need to take it to the dealer.
  2. Jun 18, 2010 at 12:02 AM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Absolutely normal, some trucks do it, other owner trucks don't. Some have tried spraying WD-40 onto it, and have said it went away. I haven't tried the WD-40 route, I just turn on the A/C at highway speeds and it seems to help.
    So you may wanna try WD-40 if it bugs ya enough....
  3. Jun 18, 2010 at 12:02 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i get it all the time. usually worse if i dont use it for a few days.
  4. Jun 18, 2010 at 12:11 AM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    WD40 worked for me, for now...i heard it comes back.
  5. Jun 18, 2010 at 12:25 AM
    06rubi
    Kenney
    Pueblo West, CO
    Thanks guys! I figured it was normal, just saved me a trip to the dealer.
  6. Jun 18, 2010 at 12:27 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    :thumbsup:
  7. Jun 18, 2010 at 12:28 AM
    numbah57
    kahai
    Maui, Hawaii
    A couple quick sprays wont hurt...I think?
  8. Jun 18, 2010 at 12:49 AM
    Yoytoda
    Roland
    completely stock
    the noise you here is the electronic clutch engaging. its driven by a solanoid so its instant, not slow and smooth. spraying wd40 is probably not the best idea. its oiling a clutch to make it slip so it wont make the engagement noise. if its like my truck, it only makes the noise the first time its been used in a while or in the morning when i just start my truck. it could be likely that condensation from engine heat attracts moisture when you park it at night. the moisture makes surface rust on the surface opposite the clutch "pad" causing it to make excessive noise when the clutch "grabs" the rough surface. after the initial engagement the surface rust wears off and there is no longer a noise. i would be afraid wd40 would cause the clutch to slip too much and the compressor wont run efficiently
  9. Jun 18, 2010 at 1:12 AM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
