Wig Wags
Discussion in 'Lighting' started by Missouriprerunner, Oct 12, 2015.
  1. Oct 12, 2015 at 8:00 PM
    Missouriprerunner
    Missouriprerunner [OP] Well-Known Member
    Adam
    STL MO
    2018 dbl cab sr5
    Haven't seen much on here about wig wags being installing in POV's or anything like that. Anyone on here ever ran them or wired them up?
  2. Oct 13, 2015 at 2:02 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    it doesn't seem to hard to wire up.... depending on what route you need to go.
    This is an example
  3. Oct 13, 2015 at 2:06 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  4. Oct 13, 2015 at 6:52 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    I really need a switch though. Like I have one switch to throw that turns on a pair of lights in my rear and in my front and then another switch to turn on the more intense lights but with that you are working the lights somehow without a switch in your dash...not sure how I feel about that
  5. Oct 13, 2015 at 6:54 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    Lol I'm confused as to what most of that in the picture is specifically referring to. I wish someone has a pictured write up on the tacoma so it would be idiot proof for me. I hate to pay someone to install what ever I end up buying.
  6. Oct 14, 2015 at 10:34 AM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    I agree needing a switch.... i didn't realize the link i posted was more for motorcycles headleights
  7. Oct 14, 2015 at 1:25 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
  8. Oct 14, 2015 at 1:39 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  9. Oct 14, 2015 at 2:57 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
  10. Oct 14, 2015 at 5:26 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    you could wire that module into one of your aftermarket set of lights instead of the stock head lights... if you wanted to.
  11. Oct 14, 2015 at 6:05 PM
    Missouriprerunner
    Adam
    STL MO
    2018 dbl cab sr5
    I thought about wiring it to my ditch lights, less intense than high beams.
