Wilco Hitchgate Solo
Discussion in 'Product Reviews' started by Unchained 5150, Aug 3, 2016.
  1. May 9, 2017 at 2:03 PM
    #521
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Just placed my order through wilco offroad! went for the hitchgate solo hi clearance w/ rotopax & hilift mount. Cant wait till it gets here!:bananadance:
    ewxlt66 likes this.
  2. May 9, 2017 at 2:05 PM
    #522
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did you use my discount
    ewxlt66 and BassAckwards[QUOTED] like this.
  3. May 9, 2017 at 2:06 PM
    #523
    BassAckwards
    yessir I did! thank you again for that!:cheers:
  4. May 10, 2017 at 7:17 AM
    #524
    BassAckwards
    @ewxlt66 Do you know if anyone has mounted a 60 inch hi-lift jack on the solo high clearance? I've seen a couple of pics with hi lifts mounted, but they all look to be the 48 inch. Just curious if they will fit both, or if it is limited to the 48. I noticed on wilco's website that they only listed the 48inch under the accessories. Any input/insight would be appreciated!
  5. May 10, 2017 at 4:31 PM
    #525
    ewxlt66
    ewxlt66 Wilco_Offroad Vendor
    Wilco Offroad, CA
    It will "fit" but you may have trouble opening it all the way. Offset it more to driver's side and it may be in the next lane.
  6. May 18, 2017 at 10:21 AM
    #526
    BassAckwards
    @Unchained 5150 do you mind posting a picture like this one except with the top of the tire and the back window/cab in it?
    Im trying to get an idea of how high it is going to be in relation to the back window of my cab high camper shell.
    In my search, i was able to come across this pic, but its with the standard solo and on an aftermarket bumper.. from comparing your pic and this one it seems the tire will be higher on the high clearance w/ the stock bumper
    If you could post a pic i would greatly appreciate it! The suspense is killing me and theres a three week lead time before mine will be shipped out.
    Thanks in advance!
    mcharfauros likes this.
  7. May 18, 2017 at 5:51 PM
    #527
    ewxlt66
    Wilco Offroad, CA
    Does this help?
  8. May 18, 2017 at 6:35 PM
    #528
    BassAckwards
    Yes this helps some, do you know what size these tires are?
  9. May 19, 2017 at 6:42 AM
    #529
    Unchained 5150
    Rick
    Auburn Ma
    My tires size is 265/75/16
  10. May 19, 2017 at 6:50 AM
    #530
    BassAckwards
    Thank you sir! :bowdown: That's the same size im running as well
  11. May 19, 2017 at 3:45 PM
    #531
    ewxlt66
    Wilco Offroad, CA
    295/70R17 if memory serves.
    BassAckwards[QUOTED] likes this.
  12. May 29, 2017 at 9:30 AM
    #532
    Rogue01
    Rogue01 New Member
    2016 Black Tacoma TRD
    I've been lurking for a LONG time. I'm so close to pulling the trigger on this, but are you able to remove the hitchgate solo easily with just one person? I primarily just want it on for the weekend adventures and not on my daily commute.
  13. May 29, 2017 at 4:31 PM
    #533
    ewxlt66
    Wilco Offroad, CA
    If you can change a tire by yourself, you are overqualified to install/uninstall this.
    It only weighs 56lbs.
    1: Remove lugs and tire, put in garage.
    2: Remove hitch pin, don't lose it.
    3: Loosen wedge lock bolt with socket and extension.
    4: Put Hitchgate Solo in garage.
    ready6delta and scottalot like this.
  14. May 31, 2017 at 9:32 AM
    #534
    Rogue01
    Rogue01 New Member
    Thanks @ewxlt66! That's exactly what I wanted to hear. I'm going to have to make some over-the-top shelving display for this thing in my garage, don't want it getting scratched
  15. Jun 1, 2017 at 6:55 AM
    #535
    Unchained 5150
    Rick
    Auburn Ma
    And don't forget to use my discount code for 10% off
    ewxlt66, Rogue01 and BassAckwards like this.
  16. Jun 16, 2017 at 1:22 PM
    #536
    BassAckwards
    Got my hi clearance solo and 3.5 gallon fuelpax mounted up. Loving it so far! Thanks again for all the help @Unchained 5150 & @ewxlt66
  17. Jul 10, 2017 at 12:08 AM
    #537
    Theloraxcross
    Theloraxcross "He's Got the Crazy Eye"
    Joseph
    San Angelo Tx
    08 AC TRD OR
    subd. for possible future purchase. Thank you @Unchained 5150 for all of the leg work on this.
  18. Jul 11, 2017 at 8:02 PM
    #538
    ElTacoGrigio
    ElTacoGrigio Active Member
    Portland, OR
    2013 AC MGM TRD Off-Road
    None....YET!!
    Quick question, what exact model is the hitchgate on the new tacoma? It looks like its offset, or is it just the angle?
    Thanks!
    ewxlt66[QUOTED] likes this.
  19. Jul 11, 2017 at 8:03 PM
    #539
    BassAckwards
    Thats the hitchgate solo hi-clearance
    ewxlt66 and Unchained 5150[OP] like this.
  20. Jul 13, 2017 at 9:53 AM
    #540
    ewxlt66
    Wilco Offroad, CA
    Yup! Thats the Solo High Clearance.
    It's just the angle of the photo. The tire will sit center of your tailgate and swings out to the passenger side
    mcharfauros and BassAckwards like this.
