Wilco Hitchgate Solo
Discussion in 'Product Reviews' started by Unchained 5150, Aug 3, 2016.
  1. Mar 9, 2018 at 11:22 AM
    #641
    ROCdermody
    ROCdermody Well-Known Member
    '16 Quicksand DCSB TRD OR
    High clearance. Love mine.
  2. Mar 9, 2018 at 11:27 AM
    #642
    Unchained 5150
    Unchained 5150 [OP] Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Just did
    ROCdermody and 01x4[QUOTED] like this.
  3. Mar 9, 2018 at 1:49 PM
    #643
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Code works, if your cart is over $600 minimum. Guess I will need to accessorize to bump it over $599.
  4. Mar 9, 2018 at 2:13 PM
    #644
    Unchained 5150
    Rick
    Auburn Ma
    Dual Rotopax Mount, License Plate Relocate Kit with LED Light.
  5. Mar 12, 2018 at 5:29 PM
    #645
    danneskjold
    danneskjold Well-Known Member
    Brian
    Shoreline, WA
    2018 F150
    Sorry for the delay - I purchased mine used on Craigslist and saved a ton of money - but at the expense of the high clearance.
    FWIW - I have a hitch mounted recovery point on my Wilco and used it in conjunction with a shittbybilt snatch strap to do 4 different recoveries this weekend in the sand. Held up great!
  6. Mar 12, 2018 at 5:33 PM
    #646
    danneskjold
    Brian
    Shoreline, WA
    2018 F150
    Here's a quick screen cap of the recovery
    ready6delta likes this.
  7. Mar 13, 2018 at 6:07 PM
    #647
    crazychris4124
    crazychris4124 Earn those pinstripes
    Westchester County, NY
    '17 Inferno Moneypit
    Too many but also not enough mods
    Do you really need the license plate kit or can you get away with just the bracket? Only using the hitch mount for off road trips and meetups
  8. Mar 13, 2018 at 6:09 PM
    #648
    danneskjold
    Brian
    Shoreline, WA
    2018 F150
    I've had mine mounted for 10,000 miles without the kit or bracket
    Tatts521 likes this.
  9. Mar 13, 2018 at 6:17 PM
    #649
    Unchained 5150
    Rick
    Auburn Ma
    After I put mine on I got stopped as my plate was in the stock spot, but I was waiting for the relocate bracket to come with the LED Light. In Mass it has to be 100% view and lit
  10. Mar 13, 2018 at 6:40 PM
    #650
    danneskjold
    Brian
    Shoreline, WA
    2018 F150
    lEast Coast sucks
  11. Mar 13, 2018 at 6:43 PM
    #651
    crazychris4124
    I'm in New York, 99% sure they will break balls over no light.
    Edit: Yup I need the light in NY
    "if required to display a number plate on the rear, a white light
    which shall illuminate the numerals on such plate in such manner as to
    render such numerals legible for at least fifty feet from the rear. The
    provisions of this subparagraph shall also apply to trailers."
  12. Mar 18, 2018 at 12:54 AM
    #652
    surfjones
    surfjones Active Member
    Casey
    Houston
    05 DCLB Sport 4x4
    Gonna order the high clearance solo. Can ya hook me up with the code?
  13. Mar 28, 2018 at 2:36 PM
    #653
    Moisttaco
    Moisttaco Member
    Western mass
    07 Silver Streak TRD
    @Unchained 5150 Would you mind sending me the code? I'm already in for a lift, rims/tires, and lights this month so if I can save some cash on my tire carrier it would be fantastic. TIA!
  14. Mar 28, 2018 at 2:54 PM
    #654
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    T4RGROUPBUY
    That will get you 10% off
    Lord Helmet likes this.
  15. Apr 9, 2018 at 12:27 PM
    #655
    blind_1560
    blind_1560 Well-Known Member
    nick
    I know this is an old post, but do you have any pics? thinking about getting one soon but wanted some feedback on it first. As far as noise or wobbles that occur when driving?
  16. Apr 9, 2018 at 12:29 PM
    #656
    blind_1560
    nick
    Do you have another code I could use? pm me
  17. Apr 11, 2018 at 5:58 PM
    #657
    andrewtheadventurer
    andrewtheadventurer Well-Known Member
    Andrew
    Somewhere probably
    Off-road Tenthouse
    an empty wallet
    T4RGROUPBUY
    blind_1560[QUOTED] likes this.
  18. Apr 12, 2018 at 3:04 PM
    #658
    SilvFx
    SilvFx Well-Known Member
    Englewood, CO
    2010 Toyota FJ Cruiser
    Toytec Ultimate 3 Lift, RCI skids, 285/70/17 BFG AT KOs
    see post on 4runner forum. Post #11 in this thread: Doesnt make noise. You do see some flex and movement in the single steel arm. The swing pivot seems fine but is just a bolt and has these nylon or HDPE washers. Hasnt worn out yet, but was concerned they would wear easily and need to be replace with brass or bronz washers.
    At the right price its a good solution especially for my 5' 4" daughter that could never lift an 85# tire/wheel combo off the roof rack. Will still be challenging for her from even the hitch rack location.
  19. Apr 12, 2018 at 3:17 PM
    #659
    blind_1560
    nick
    What would be a good price range for it? Cheapest I saw it was roughly $590
  20. Apr 12, 2018 at 5:56 PM
    #660
    SilvFx
    Englewood, CO
    if you look at my thread that I linked to....the very first line I indicate that I paid $390 for it. I think the plate relocate kit was addl $65 or so.
