Will 285/70R17 tires fit?
Discussion in 'Wheels & Tires' started by izu_yo, Apr 1, 2010.
  1. Apr 1, 2010 at 11:03 PM
    izu_yo
    izu_yo [OP] Active Member
    Calgary
    2010 Black TRD Sport
    Hi All,
    I tried searching the forum for an answer but wasn't able to find what I was looking for. Any insight you guys and girls can provide will be greatly appreciated.:yay:
    I will be lifting the front end of my 2010 TRD Sport using 5100's set at 1.75 with stock springs.
    Will I be able to put on a set of 285/70R17 tires without rubbing issues?
    Thank you.
  2. Apr 1, 2010 at 11:07 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    haha man that fucking classic!
    to the op: its the same as the pre 2010 so maybe search for the 2005-2009 range :)
  3. Apr 1, 2010 at 11:07 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Set em to 2.5 setting and they will fit with minor rubbing, after minor triming.
  4. Apr 2, 2010 at 8:55 AM
    izu_yo
    Calgary
    lol... search button...:D
    08pretaco: thanks for the advice, i will look it up.
    senor taco: checked out your build. your truck is sick! i'll def keep your advice in mind since you're running pretty much what i'm looking at doing.
    cheers
  5. May 17, 2012 at 6:48 PM
    Datsik
    Datsik Well-Known Member
    Anthony
    San Diego
    1999 Tacoma 4x4
    Not much.
    What kind of trimming do you have to do. And what tool would be preferred?
  6. May 17, 2012 at 8:10 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    For cutting the plastic, I like using a sharp wood chisel.
    EDIT: Also, for reshaping the plastic of wheelwell and fender flare, a heat gun is absolutely great.
    For the pinch weld and cab mount chop, grinder, engineers hammer, welder.
  7. May 17, 2012 at 11:36 PM
    Datsik
    Anthony
    San Diego
    1999 Tacoma 4x4
    Not much.
    Is all that really necessary to get a 285/70/17 tire under a 2.5" lift in the front?
  8. May 18, 2012 at 7:58 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Before I answer that -- the other tool that's really handy is a heat gun. It's great for reshaping all that soft plastic.
    But as far as the NEED for trimming goes: Your mileage may vary. But I did all that to run 285/70R17 on a 3" lift.
    It just depends on your tolerance for rubbing, and how you use the truck.
    But remember the wheel well doesn't change size when you lift. And the truck's only at the full lifted height when parked. Once you're on the road, hitting bumps, turning, backing up, the suspension is cycling dynamically.
    And when the suspension's fully compressed, the wheel goes just as far into the wheel well on a lifted truck as an un-lifted truck. (exception: top plate spacer lifts. But that's a whole different discussion.)
    I talked to one shop owner who didn't trim his customers' trucks aggressively - he just told them not to turn to hard-steering-lock to avoid contact. :rolleyes: Some folks would prefer that vs. taking off pieces of their inner wheelwell. Whatever. I suppose that plan makes sense if you're only going to have the truck a little while, and you plan to return the truck to stock at the end of a lease, or when you sell it less than four years old.
    To each their own. I'd rather have fully clearanced tires. And the trimming is not obvious to anyone who doesn't get down and look INSIDE the wheelwell. Even then, folks who don't know what they're looking for usually won't notice.
  9. May 18, 2012 at 3:16 PM
    evh5150
    evh5150 Well-Known Member
    Eddie
    Auburn,Ma
    2010 D/C S/B V6 6 Speed
    Bilstein/5100 combo from Toytec. LR UCA's.1.5 AAL's Full audio upgrade.Pioneer 8400, JL Audio subs. All Boston Acoustic pro speakers, and a Kenwood XRS 5 amp. Grillcraft, Smittybuilt stainless steps. Debadged. Soon 17x8 ATX Ledge wheels w/285/70/17 BF Goodrich
    Do you really have to re gear for 33's I only mainly do city driving, with a little highway. I know I will lose mpg's
  10. May 18, 2012 at 3:20 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    I love my 33's, you will lose some power and will "feel" it, my mpgs went down 1-2 from what they were. Im pretty even highway/city.... Im getting roughly 16 per gallon when i do 70. Ive dropped down to doing 63-65 and my mpg's are about 17-17.5 now
  11. May 18, 2012 at 3:20 PM
    Blueinstinct
    Blueinstinct Well-Known Member
    Ed
    Orange County
    07 Trd Sport
    1.25" lift spacer, K&N intake, K&N Oil Filter, Window Tint, AVS Window visors, Extang Tri-fold bed cover, Pro Comp Wheels Series 7089 17", Federal Couragia M/T Tires Lt285/70R17, NRG Racing lug nuts flat black, Crystal Headlights, HID xenon 6000k, HID xenon 3000k, Blacked out Grill and Emblem, Pop&Lock Tailgate Lock, Pioneer 5.8" InDash Double din, 13" Aspheric Rearview Mirror, Wade Sure-fit front floor mats, Eurow sideless sport mesh seat cover, Smd Led Map lights, City lights, License plate lights and Dome light.
  12. May 18, 2012 at 3:32 PM
    evh5150
    Eddie
    Auburn,Ma
    So I already have a full 3 inches of front with the assembled 5100/Eibach combo. No mudflaps. What else would I need to do? I am ordering ATX Slot in chrome (Yes I know I expect the haters). I guess I will need the 1.25 Spidertrax spacers. Oh and I have LR UCA's
  13. May 18, 2012 at 3:35 PM
    BulletToothTony
    Whats to offset on the rims you may not need the spacers...
  14. May 18, 2012 at 3:38 PM
    evh5150
    Eddie
    Auburn,Ma
  15. May 18, 2012 at 3:39 PM
    BulletToothTony
    Yeah i probably would, you may be able to make without, but then again im a big fan of having the wheel stick out alittle :D
  16. May 18, 2012 at 3:40 PM
    evh5150
    Eddie
    Auburn,Ma
    me to, the other one i am looking at is -12
  17. May 18, 2012 at 3:43 PM
    BulletToothTony
    Im not an expert on rims at all lol i would pm this guy KPT he will answer all your questions correctly...
  18. May 18, 2012 at 3:43 PM
    evh5150
    Eddie
    Auburn,Ma
    I like the XD Revolver as well
  19. May 18, 2012 at 3:43 PM
    evh5150
    Eddie
    Auburn,Ma
    Thanks bro
  20. May 18, 2012 at 3:44 PM
    BulletToothTony
    Those are cool, im partial to the machined addicts myself :devil:
