Will 285/75/16 with 5" Backspacing Fit w 3" Lift?
Discussion in 'Wheels & Tires' started by iJDub, Mar 24, 2013.
  1. Mar 24, 2013 at 11:40 AM
    iJDub
    iJDub [OP] Well-Known Member
    With a 3" lift will 285/75/16 w/5" BS fit without rubbing or cutting?
  2. Mar 24, 2013 at 11:49 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
  3. Mar 24, 2013 at 12:01 PM
    iJDub
    What will I be rubbing on and what will I need to modify? Should I go with 285/70/16s instead?
  4. Mar 24, 2013 at 12:16 PM
    taco47001
    taco47001 Newborn
    Aurora, IN
    LX470
    Since you didn't specify what vehicle you will be placing this setup on....you will be rubbing on everything. Something with less backspacing would probably be a start.....
  5. Mar 24, 2013 at 12:33 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    maybe if we knew what truck yer putting those on...
    we could possibly be of assistance
  6. Mar 24, 2013 at 5:06 PM
    iJDub
    Oh sorry, 4x4 Double Cab 06 TRD OR
  7. Mar 24, 2013 at 6:46 PM
    jdk52
    jdk52 Bro do you even 'Merica?
    Utah
    11 SR5
    3 inch OME lift kit, rear diff breather mod, cb install, sliders, brute force fab front end.
    With those tires you'll still rub on the fender wells regardless of the backspacing. A razor blade, wire snips, or heat gun will be your friend.
  8. Mar 25, 2013 at 1:26 AM
    DevL
    DevL Well-Known Member
    You 3" lift has zero impact on rubbing. Please read previous posts as this has been covered ad nauseum. You want a 285 width 33" tire? You need a cab mount chop and lots of trimming.
