Will 5100 or stock shock fit a 3 inch lift?
Discussion in 'Suspension' started by ERdept, Mar 25, 2008.
  1. Mar 25, 2008 at 2:37 AM
    ERdept
    ERdept [OP] Well-Known Member
  2. Mar 25, 2008 at 7:06 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    5100's will fit but only at stock height. Do not try to set the 5100's at anything above the stock setting and they will fit fine and give you a great ride
  3. Mar 25, 2008 at 10:05 AM
    ERdept
    OK, so I can't use the 5100's. And setting them for anything is not even a consideration since they won't fit.
    Again, what should I buy or will stock fit a 3 inch lift?
  4. Mar 25, 2008 at 10:15 AM
    nd
    Nate
    Greenville, SC
    stock will fit. but if you want to use the 5100's you can. they have a stock setting and will fit fine and give you a slightly better ride than stock. if you are gonna use anything other than stock shocks i recomend 5100's. they are a great ride and you can always adjust later if you need to for any reason
