Will 5100's set at .85 help clear tires?
Discussion in 'Suspension' started by beeesmitty, Jul 18, 2012.
  1. Jul 18, 2012 at 7:02 AM
    beeesmitty
    beeesmitty [OP] Well-Known Member
    NC
    11' SR5 DC BSP 4X4
    265/75/16 DuraTracs, MB TKO 16x8.5, 5100's @ 2.75, ReadyLift 2" Blocks
    Hi all,
    265/75/16 BFG's, MB TKO 16,8.5 wheels. Mudflaps off.
    I am having some rubbing on the rear of the front fender while turning going forward and rubbing on the front of the front fender while turning in reverse.
    My question for you guys is will 5100's set at .85 remedy this rubbing, or do I have to trim regardless? I don't want to trim and raise it. I don't mind doing one or the other, but not both unless it is imperative. I would only put the 5100's on only to fix the rubbing as I don't care to raise the truck.
    What are you guys thoughts? raise it and see if I still need to trim, or just trim it and forget about the 5100's? Looking for 1st hand knowledge about .85 being enough for clearance. Thanks!
  2. Jul 18, 2012 at 7:11 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    ehh... its hard to say if 0.85" of lift will prevent the rubbing. but, for certain, trimming will prevent the rubbing. and trimming is cheaper than buying new shocks :)
  3. Jul 18, 2012 at 8:47 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Whats the backspaing of the wheels?
  4. Jul 18, 2012 at 10:10 AM
    beeesmitty
    NC
    11' SR5 DC BSP 4X4
    Thanks for the replies guys.
    4 16X8.5 6-139.7 -6MTB MB TKO- this was on my invoice
    16x8.5 -6mm offset (4.5"BS) - found this online
  5. Jul 18, 2012 at 10:36 AM
    DevL
    DevL Well-Known Member
    Lift has zero effect in rubbing... you will still rub in compression and eventually damage something.
  6. Jul 18, 2012 at 10:45 AM
    KPT
    09 Prerunner
    The 0.85 would likely alleviate the rubbing when not flexed.
  7. Jul 18, 2012 at 10:47 AM
    beeesmitty
    NC
    11' SR5 DC BSP 4X4
    So trimming will keep from rubbing in compression/flexed?
  8. Jul 18, 2012 at 10:49 AM
    KPT
    09 Prerunner
    That's highly dependent on how much trimming you are willing to do.
    With the 265's, I wouldn't expect you to have to do much. You're just rubbing slightly because the wheels you selected stick out 2.5" more than stock.
  9. Jul 18, 2012 at 10:56 AM
    beeesmitty
    NC
    11' SR5 DC BSP 4X4
    Thanks,
    I guess I could do both. I'm just mainly concerned with premature wear/integrity of the suspension by raising it.
  10. Jul 19, 2012 at 10:56 AM
    NetMonkey
    Geogetown, TX
    there will be very little wear at 0.85" of lift. you need to get to 3 or more inches to cause wear.
  11. Jul 19, 2012 at 1:52 PM
    DevL
    Do not worry about wear if under 2.5" of lift.
    Do worry about rubbing with new UCAs, tires 11.5" wide or wider, tires 33" tall or taller.
    Clearance can be as simple as removing the mudflaps or as complicated as a cab mount chop, hammering pich weld, trimming fender metal, and heavy plastic cutting of both the flare and fender liner. Depends on your installed components.
  12. Jul 22, 2012 at 11:43 AM
    beeesmitty
    NC
    11' SR5 DC BSP 4X4
    Thanks for all the input guys. I'm going to do a little trimming this evening and see if I can take care of it.
