will a 2.4L work in a 2.7 4wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by STRYTLR, Nov 25, 2011.
  1. Nov 25, 2011 at 4:39 AM
    STRYTLR
    STRYTLR [OP] Member
    GT
    Central FLA
    '96 Taco 4X4 4.5" Lift CoilOvers 2.7L // 5spd
    Fabtech Coil Overs,Add -a- Leafs,2" Body Lift,33" A/T's
    I've got a 1996 Tacoma 4wd with a bad 2.7L motor, (8 port/ distributor)
    will a 2.4L from a junkyard work, 2.7L's are hard to find and the ones i did find are a fortune, I managed to find a good little 2.4 and was wondering if the wire harness, and all connections will work without any mods,, if it's plug and play, i may opt for the 2.4L 500.00 is much better than 1300.00, thanks in advance for any help
    :D
    I'm sure this question has been asked before,,,:cool:
  2. Nov 25, 2011 at 9:02 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    ey my truck had the original 2.7l enine. i put in the 2.4 in there and everything plugs in play. i didn't swap it myself, had the shop did it. but i asked around and the mechanics said the 4 cycl. are interchangeble. plug and play. maybe will have to change the ecu too. but the gas milages will suck if you have bigger tires.
  3. Nov 25, 2011 at 9:03 AM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    i'm planning to swap back to the 2.7 motor sometime soon. yeah the 2.7 does cost a fortune but i'm keeping this truck for many more years to come.
  4. Nov 26, 2011 at 6:15 PM
    STRYTLR
    STRYTLR [OP] Member
    GT
    Central FLA
    if you change the ecu, wouldn't that disable the 4wd?
  5. Nov 30, 2011 at 2:35 AM
    ilove_taco_ma
    fresno, california
    95 tacoma 4wd LX
    I haven't check if the ecu is still the 3rz or the 2rz. But the 4wd does engage when it's in use.
