Will a 4.77in back spacing work
Discussion in 'Wheels & Tires' started by Taco zilla, Feb 12, 2012.
  1. Feb 12, 2012 at 4:16 AM
    Taco zilla
    Taco zilla [OP] Member
    Shane
    South Carolina
    2011 Tacoma 4x4
    20x12 Fuel Hostage's with 33x13.00 super swamper iroks. 6" Fabtech susp lift. Borla exhaust 5% window tint. 4wd luminated switch
    Im wanting to go with a 20x12 & all I can find for my 2011 Tacoma (6 on 5.5) is a 4.77in back space. I wanna make sure they'll work, & not hit the caliper or anything else for that matter. Has anyone went with a 20x12, & if so what dimensions far as offset & back spacing? Thanks
  2. Feb 12, 2012 at 7:33 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    20x12"? That wayyyyyyy to wide unless your are running a 37x15 or something like that. What size tire do you want to run, on how much lift?
  3. Feb 12, 2012 at 7:34 AM
    jandrews
    '09 FourDubDee TRD OR
    12" wide wheel? Most people run 8 or 9" width. I like 7.5" myself.
    More info needed on planned tire size and suspension.
  4. Feb 12, 2012 at 7:41 AM
    TexasTacoma37
    Just looked at his profile and he's apparently already running a 10" wide wheel with 265s. Lucky to not have popped a bead yet.
  5. Feb 12, 2012 at 8:25 AM
    jandrews
    Indeed on both accounts.
  6. Feb 12, 2012 at 3:25 PM
    Taco zilla
    Shane
    South Carolina
    2011 Tacoma 4x4
    Installing Fabtech stage III 6in lift with 35x12.5x20 Nitto Mud Grapplers. And yes the tires will blow up on the 12in wide wheel, and no i'm not worried bout busting the bead off the rim. The only time you need to worry bout that is if you're going to be going off road. Even then you'll be fine, just lower the tire pressure. I just need to know if the 4.77in back space will hit the caliper. It's mostly going to be a show truck, thanks for any info on the wheels only!!
  7. Feb 12, 2012 at 3:32 PM
    TexasTacoma37
    Hitting the caliper has nothing to do with backspacing, it has to do with spoke design of the particular rim. Ive never heard of any 20s not clearing the caliper.
    What you really need to be worried about with the backspacing is the tires hitting the uca, but seeing as how you are running them on an incredibly wide rim (nitto website recommends a 10" wide rim for that size mud grappler) it will pull the tires far enough away from the uca where you will be fine.
    However a 4.75" bs rim that's 12" wide will sick out almost 6" more than stock, so you'll have plenty of cutting and grinding to do to fit those without rubbing, even on-road.
  8. Feb 12, 2012 at 3:34 PM
    TexasTacoma37
    Airing down would make them more prone to break the bead, not less prone.
  9. Feb 12, 2012 at 3:41 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    this
  10. Feb 12, 2012 at 3:48 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    give him a break...he's from SC....:rolleyes:
  11. Feb 12, 2012 at 3:50 PM
    ColtsTRD
    Scott
    AZ
    No excuses around here!
  12. Feb 12, 2012 at 3:51 PM
    The_Hodge
    SC
    the wheel/tire combo does sound mighty hawaiian of him though...way to think interstatal...
  13. Feb 12, 2012 at 3:54 PM
    ColtsTRD
    Scott
    AZ
    That's a nice way of putting it :D
  14. Feb 12, 2012 at 3:59 PM
    TexasTacoma37
    Btw OP, it's going to look like this, except even skinnier of a tire. These are 13.5"s on 12" wide rims.
  15. Feb 12, 2012 at 4:00 PM
    ColtsTRD
    Scott
    AZ
    :redxfall:
  16. Feb 12, 2012 at 4:02 PM
    TexasTacoma37
    You are too fast my friend.
  17. Feb 12, 2012 at 4:02 PM
    jandrews
    Nothing to do here...just reading the reply was enough retard for today...
  18. Feb 12, 2012 at 4:03 PM
    ColtsTRD
    Scott
    AZ
    :rofl:
  19. Feb 12, 2012 at 4:03 PM
    ColtsTRD
    Scott
    AZ
    Poor truck :(
  20. Feb 12, 2012 at 5:15 PM
    Taco zilla
    Shane
    South Carolina
    2011 Tacoma 4x4
    Well, I thought this was a forum where (ADULTS) could come on here to give & ask for info about their Tacoma's! Guess I was wrong, must be a website where 6th graders are dreaming about their 1st truck! Thanks KPT for your info, atleast you acted like you were actualy trying to help!
