Will I need 2 alignments?
Discussion in '1st Gen. Tacomas (1995-2004)' started by nick64646, Mar 19, 2012.
  1. Mar 19, 2012 at 1:19 AM
    nick64646
    nick64646 [OP] Active Member
    Nick
    BC, Canada
    1997 Toyota Tacoma 4x4
    Bilstein 5100's on all 4 corners, front at 2.5", Wheelers 1.5" aal, K&N intake, magnaflow exhaust, ARB Bumper with a lightbar, 1.5" CB drop, BPV bracket
    Hey so my trucks gunna be going in getting the eibachs and lr uca's installed soon and I was wondering If I get an alignment after that is done will I have to get another one when I get new tires a month or two down the road?
    Thanks, Nick
  2. Mar 19, 2012 at 1:24 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    no
  3. Mar 19, 2012 at 5:35 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :thumbsup:
    Unless something happens in the few months you're waiting tires that makes you think your alignment is off, you shouldn't need another alignment. If you're buying the tire manufacturer's extended warranty, read the fine print. Sometimes they require you to get an alignment at the time of install otherwise they won't cover the tires.
  4. Mar 19, 2012 at 8:50 AM
    defleppardsg
    defleppardsg Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    idk why they're telling you no. before I swapped my coils for OME's, I was told that the springs were going to settle, and I'd need an alignment a couple of weeks after the install. It depends on how bad the truck feels right after the install I guess... I didn't have them align it after the install, and it wasn't bad at all, then 2 weeks later I got everything re-tightened and aligned.
    But my mechanic said that he's known guys that put lifts on their truck, and the trucks would pull to one side like crazy afterwards, until it was re-aligned. But regardless, the new springs are going to settle, and you're going to need a re-alignment down the road- whether its 2 weeks or 6 months later. I'd try to get away without it at first if you don't have much driving to do.
  5. Mar 19, 2012 at 8:54 AM
    Pugga
    Massachusetts
    Unless you really give the suspension a workout in the first couple weeks, the springs aren't going to settle enough to say so in the first couple weeks. The first time you drive it down a semi-bumpy road, everything will set in place, that's when you want to retorque everything and get the truck aligned. After the install, the short drive to the alignment shop is more than enough to make everything 'settle'.
