Will I regret this??
Discussion in 'Suspension' started by bendbolden, Oct 22, 2011.
  1. Oct 22, 2011 at 1:03 PM
    bendbolden
    bendbolden [OP] Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I am going to be installing 5100's in the front this week at 1.75. Shocks and leaf springs are all stock. If I add a 1" block in the back will I really see any axle wrap or any other problems? Also this is mostly my daily driver. I don't really do any heavy off roading. I know this isn't my best option and I will eventually get new leaf packs but right now I can't.
  2. Oct 22, 2011 at 1:06 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    5100s up front should be fine & the rear why not add a aal
  3. Oct 22, 2011 at 1:12 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I don't want to run the 5100's at 2.5" and I was afraid if I go with the smaller 1.5" AAL that it would still have the rear high rake. Do you think the 1.5" AAL and 5100's set at 1.75 will be about level?
  4. Oct 22, 2011 at 1:13 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I shouldn't need new U bolts for the AAL wither should I?
  5. Oct 22, 2011 at 1:16 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Lastly will the AAL be okay with the stock rear shock or will I need to go with 5100's in the rear?
  6. Oct 22, 2011 at 1:17 PM
    The1youluv2hate
    Peps
    SAnta Paula CA
    I think you can use stock u bolts just use the center pin that comes with new aal
  7. Oct 22, 2011 at 1:20 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    you will be level with the front at 1.75 and nothing in the rear...
  8. Oct 22, 2011 at 1:27 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    I will just put the 5100's on first and go from there. I have this annoying clunk in the rear when I go over any decent sized bump. I took it to the dealer today and he automatically said I need new leaf springs at only 70k miles. That doesn't sound right.
  9. Oct 22, 2011 at 3:14 PM
    PEPCATCH11
    PEPCATCH11 Well-Known Member
    Dan
    Tulsa, OK
    2011 Regular Cab
    TRD skid plate, Bilstein 5100 struts @ 2.5", Bilstein 5100 shocks, Wheeler's 1.5" AAL, Spidertrax 1.25" wheel spacers, BFG KM2 285/75/16
    The Bilstein 5100's set at 2.5" using the stock springs and a 1.5" AAL with the stock non-TSB leaf springs will level the truck...about 1" rake. Just FYI.
  10. Oct 22, 2011 at 3:25 PM
    Iceman2448
    Iceman2448 Well-Known Member
    Ga
    5100 OME 3" front lift 1.5 rear All Injen cold air Intake N-Fab light bar Hella 500FF lights Alpine Heand unit Type R 10 sub r500.1 amp Alpine 6x8 comps up front Alpine 6x9 in rear
    That's how my truck is and it ride great, but I do have 5100's all the way around.
  11. Oct 24, 2011 at 2:38 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    Sounds right on the leafs... Stock leafs aren't the greatest and blocks are instant axle wrap...
    Are your leaf springs flat or even de-arched?
  12. Oct 24, 2011 at 2:47 PM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    No they still have a good arch to them. I can really jump on the back of the truck and simulate the clunk. I didn't look at it but the tech told me they weren't bottoming out. There are clearly marks on the bump stops though. Either way I think an AAL will solve my problems. I am eventually going to get a new leaf pack and new shocks in the rear and new springs in the front.
