Will it work?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MedlinAround, Jan 15, 2011.
  1. Jan 15, 2011 at 12:42 AM
    MedlinAround
    MedlinAround [OP] Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    If i got the Bilstein 5100's (Front and Rear) Front set 2.5", add 1.5" Rear Leaf added 275/65/17's without rubbing?
    Or do you think the front should be set to 1.75". I want to be able to tell its lifted a little but not kill my MPG. Don't want any bigger than 275/65 or 275/70's on it.
    This a reasonable idea or how would you go about it?
  2. Jan 15, 2011 at 1:12 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Well if MPG is a big concern? Then just leave your truck stock, and drive it until the tires wear out.
    Use all your additional money you have to pay off the truck as fast as you can.
    Then get a good lift! And without a monthly loan to pay; you won't be so concerned about MPG! And you'll enjoy your truck a lot more!
  3. Jan 15, 2011 at 1:42 AM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    yea, i mean i got my tirs 265/75/16 when i put on my billies at .85 and after the alinement i noticed a difference when i picked up my truck......
    but i think any more than that would be noticeable
  4. Jan 15, 2011 at 9:22 AM
    MedlinAround
    Cody
    Kentucky
    well i'm not that concerned about it, just don't want it dropping to something ridiculous.
  5. Jan 15, 2011 at 10:32 AM
    MedlinAround
    Cody
    Kentucky
    I've been going at the tire sizes all wrong. Such as i figured 275/65/17 would be bigger than 265/75 simply because stock size is 265 but its simply 265/70 stock size is the same with as 265/75 but the diameter is quite a bit larger.
  6. Jan 15, 2011 at 10:50 AM
    toku58
    Mall Crawler!
    well I'm running 35" tires and I get about 15 mpg. (After you calculate the diameter of the tires)
    When I had the stock tires on I was getting 18 mpg. So a drop of 3 mpg isn't that bad.
    Think of each tire size up, as one person riding in the truck with you. That's about the amount it will affect your mpg.
    So my truck mpg is like I have 4 friends ride around with me.:D
  7. Jan 15, 2011 at 10:53 AM
    toku58
    Mall Crawler!
    Your original question? You'll more than likely need to trim some plastic. You may rub but it won't be all the time. just when turning and hitting bumps. (More noticeable in reverse)
