Will, Jhodge, 007, and all engine guys!!!
Discussion in 'Technical Chat' started by chris4x4, Jan 12, 2009.
  1. Jan 12, 2009 at 11:08 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have a theory as to why newer engines have less mpg as opposed to, say, one with 20,000 miles or so. Not to go into the "breaking in" of the engine, but in the last year I have been tracking spark plug gaps at a 30,000 mile change, or there about. Seems the majority of the people that change the plugs at this interval have spark plug gaps of .040 to .041. Min. spec. is .039, with .043 being a max. In my experiance, plug gaps grow about .003 to .005 in 30,000 miles (copper/nickel plugs). My theory is that the plugs from the factory are gapped at .035 or so. This will make the spark more reliable, but it will be a small spark, causeing a rich condition of the engine, as the burn will be largly incomplete. Not enough to trip a code, but enough to affect mpg. As the miles are put on and the gap grows to .040, the spark will be larger, creating a more propperly ignited air/fuel charge. Im thinking this could also be one of the reasons that the engine, in some cases, wont light on the first starting attempt.
    What say you?
  2. Jan 12, 2009 at 11:10 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    finally doing something constructive with your free time i see:)
  3. Jan 12, 2009 at 11:14 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    ^ :laugh:
    And the theory seems pretty sound to me. The same should hold true when installing an MSD ignition in the same vehicle. More thorough fuel burn should definitely improve power and economy.
    But then I could just be talking out of my ass. Subscribed to follow the discussion.
  4. Jan 12, 2009 at 11:15 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Well that would make sense and also explain the "slow" start. I wonder if any of the toyota techs on here would be able to go pull the plugs from a new 09 and check the gap???
  5. Jan 12, 2009 at 11:22 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    While, I think you have a good point, I'm going with the break in period. Once the engine has a chance to loosen up it moves easier.
  6. Jan 12, 2009 at 11:26 AM
    sonjay
    sonjay Well-Known Member
    Your theory sounds solid, I'll be changing my plugs in a little bit, I'll be sure to check the gap on them. Anyone that has owned an air-cooled VW knows the importance of spark plugs, gap, and having many spares!!
  7. Jan 12, 2009 at 11:38 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you measured the actual gap on a bran new plug on a new tacoma?
  8. Jan 12, 2009 at 1:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not on a new one. But I dont belive they only grow .001 to .002" in 30,000 miles. No way.
  9. Jan 12, 2009 at 1:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, I know....BUT, the engines are mostly broken in at the factory. Not saying they dont "Loosen up", but I have been wondering why there have been some starting issues (slow start, no start, etc.), but after some 10,000 miles, there isnt. Slow starting, and periodic No start isnt going to be caused by a "tight" engine.
  10. Jan 12, 2009 at 1:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, well........Im tired.
    an MSD ignition wont work on the Tacomas. They only work on central ignition systems (as far as I know) Plus, the stock system puts out more voltage than the MSD's.
  11. Jan 12, 2009 at 1:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Let me know the miles, and gap of the plugs. I have about 15 vehicles that I have checked on, and they all have had spark plugs gapped at about .040 to .041, and their milage has been between 27,000 and 34,000 miles. Im betting yours are gonna be the same.
  12. Jan 12, 2009 at 1:16 PM
    mjp2
    NJ
    It was more of a theoretical idea than a direct application. Since the coil-on-plug design came out I haven't heard much from the MSD crowd. Good to know that there's a reason for it. :)
  13. Jan 12, 2009 at 2:19 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    glad to know someone thinks i know what the hell is going on...lol. if i can find my gap chip i'll try to pull one from mine tomorrow and let ya know.
  14. Jan 12, 2009 at 2:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks.
  15. Jan 12, 2009 at 2:27 PM
    JimBeam
    JB
    2015 Tundra
    yall should check luni's new ones too...with the mileage...see where he's at
  16. Jan 12, 2009 at 2:30 PM
    The_Hodge
    SC
    yeah...i've got about 7k miles on mine. his is a lil fresher.
  17. Jan 12, 2009 at 2:37 PM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    sounds good in therory, but i say unplug or add a resistor inline with the coolant temp sensor on a new truck and see if you can lean out the mixture on cold start.
  18. Jan 12, 2009 at 2:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    valid point Chris. sounds right to me..........as when i changed the plugs on my 06.....didnt check the gap on them when i got the truck, but when i pulled them....they were gapped properly.....all right around .041. new plugs that i got............had to gap them myself..even tho they were supposed to be gapped from the factory to .040 or so....they were around .035..........and this is with the copper plugs on the 06 i had and the 04 i have now.
  19. Jan 12, 2009 at 2:50 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    AWSOME! Thats what I was thinking. A .035 gap is gonna give a weak spark. Thanks Will.
  20. Jan 12, 2009 at 2:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think that would cause more harm than good.
