Will, Jhodge, 007, and all engine guys!!!
Discussion in 'Technical Chat' started by chris4x4, Jan 12, 2009.
  1. Jan 17, 2009 at 7:47 PM
    #41
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    .044 and .048 sounds like the normal gap expansion, but the .050 is out of spec, and pushing the limits of the plug. Thanks for the info. :)
  2. Jan 23, 2009 at 5:13 PM
    #42
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    just finished changing mine today, with the denso's on one side and ngk's on the other. the smallest gap was 0.45 with the biggest being 0.45, I think two of the denso's were 0.45 while the ngk's seemed to have the bigger gaps, if that means anything. The denso's I bought at the stealership were all .060
  3. Jan 23, 2009 at 5:37 PM
    #43
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hope you regapped them to .040. how long did it take ya,Jon???:D
  4. Jan 23, 2009 at 5:48 PM
    #44
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    yes, regapped to .040, took about 45 total. happy?:D
  5. Jan 23, 2009 at 5:49 PM
    #45
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    kickass!! good job!:D
  6. Jan 23, 2009 at 8:41 PM
    #46
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    I guess that's why I have carbon build up on my tailpipe? :confused:
  7. Jan 23, 2009 at 8:46 PM
    #47
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think that is more dertermined by your right foot. When you are due for a spark plug change, I'll check out your plugs. ;)
  8. Jan 23, 2009 at 8:47 PM
    #48
    Packman73
    2007 TRD Off Road
    Ahhh, gotcha. ;)
