Will not Start in Gear even w/ clutch in
Discussion in '1st Gen. Tacomas (1995-2004)' started by sixthreezerodub, Nov 27, 2007.
  1. Nov 27, 2007 at 7:17 AM
    sixthreezerodub
    sixthreezerodub [OP] New Member
    03 VW GTI 1.8T
    hi,
    new to this forum, don't even own a truck. I am posting this for a friend.
    Her Truck (99 4cly) will not start in gear even with the clutch in. It only starts out of gear. The clutch is working fine, not slipping or falling out of gear or anything. I m pretty unfamilar with toyota's but I know my car has a clutch position sensor under the clutch pedal. Do the Tacoma's have a simalr setup? or any ideas? thanks ahead of time.
  2. Nov 27, 2007 at 10:55 AM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    yes there is a small switch under the clutch pedal on the floor, i would check that out to make sure its working properly.
