Will Pro Comp 7089s 16x8 work on my 2010 prerunner??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JakeS, May 13, 2014.
  1. May 13, 2014 at 4:02 PM
    JakeS
    JakeS [OP] Member
    Jake
    Arkansas
    2010 DC TRD Off-Road Prerunner
    I have 2010 DC prerunner and wanted to get the Pro Comp 7089 rims in 16x8 4.5 back spacing. I am getting 265/75/16 bfg all terrains this week. Any body know if I can run these rims on my truck without too much rubbing on stock suspension and will they rub the brakes? PICS WOULD BE GREAT
    Thanks!
  2. Jun 12, 2014 at 8:42 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    They should work. I had 16x10 on my truck, but that was with a 3 inch lift and 33s
  3. Jun 16, 2014 at 7:34 PM
    JakeS
    JakeS [OP] Member
    Jake
    Arkansas
    Going to order rims tomorrow! Which lug nuts do I need for these wheels?
  4. Jul 8, 2014 at 4:13 PM
    moondeath
    moondeath The answer to divorce...... Tequila!
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
  5. Jul 8, 2014 at 5:16 PM
    moondeath
    Pa, Carlisle
    Also, you will probably have just a slight rub while turning with no lift. With a slight lift it will eliminate any rubbing. The tire size would normally fit, but the 7089's have 0 offset which moves the tires outwards.
    The 16" 7089's will clear the calipers.
  6. Jul 8, 2014 at 5:25 PM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    How do you figure that adding lift will get rid of rubbing? Suspension still cycles the same distance whether it's stock or lifted.
  7. Jul 8, 2014 at 5:51 PM
    moondeath
    Pa, Carlisle
    The 7089's move the tire away from the frame because of more offset. Moving the tires closer to the outer wheel well plastic. That's what it rubs. I had this issue before lifting. After you lift the truck, it lifts the wheel well away from the tire, hence eliminating wheel rub.
  8. Jul 8, 2014 at 6:14 PM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Until you take it offroad... Lift will not magically get rid of rubbing.
  9. Jul 8, 2014 at 6:23 PM
    moondeath
    Pa, Carlisle
    I haven't had a single incident of rubbing since lifting in 25k miles. Even if you were off-roading hard enough to compress that far, the world will keep spinning.
