will remounting tires help with balance issues?
Discussion in 'Wheels & Tires' started by MTgirl, Oct 19, 2010.
  1. Oct 19, 2010 at 10:52 AM
    MTgirl
    MTgirl [OP] too many frogs, not enough princes... Moderator
    Weesa
    Bob's secret mod lair
    well mine aren't 13oz out of whack but here's what I've got...tire loaction, weight on outside, inside, and relative position of the two.
    drivers side - front - outside 2.25 inside 1.75 (approx 90 deg. apart on the rim)
    drivers side - rear - 1.75 and 1.5 (180 deg)
    passenger - front - 1.25 and .25 (180 deg)
    passenger - rear - 1.75 and 2.75 (same)
    the vibes that I'm getting too are more in the seat/floor and not through the steering wheel - thinking that means its got to be one of the rear tires?
  2. Oct 19, 2010 at 10:56 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    if your getting in the seat then its the rears
    but on that front one on the d/s are the weights across from each
  3. Oct 19, 2010 at 11:06 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    that's mine I bought them from Tire Rack the wheels and tires are brand new. i asked the same question when they told me it took 13oz to balance the rears.
    The reason it took so much is that the size of the wheel is 15" and there is only so much clearance so weights are placed on the inside edge of the wheel and I have a really aggressive offset -44mm.
  4. Oct 19, 2010 at 11:27 AM
    MTgirl
    Weesa
    PM sent! :rolleyes: now back to the business at hand...
    the weights are placed at approx. 3oclock outside and 6oclock inside on that one.
    Just got done with my calls...my shop doesn't do road force balancing but there is another place in town that does, $50 to have them do it. another place does optima balancing? they said its similar?
    going to give my guys one more chance and then resort to the road force if necessary. and yes, david, I'm always nice. Unless they give me crap...then I call my mommy and she calls the owner of the place and then he calls the shop and tells them to quit giving me crap :D
  5. Oct 19, 2010 at 11:41 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    Optima balancing is similar in that its' purpose is the same, but the technology is different. Road force applies physical force to the tire, whereas Optima uses lasers and cameras with no contact to the tire. Though I have a lot of experience with road force balancing, I can't speak for the Optima method as I have never used it myself.
  6. Oct 19, 2010 at 11:52 AM
    David Tarantino
    N.J.
    08 tacoma
    Optima balance is what i use it works great
    i have balanced a lot of tires for guys here no one has ever
    had to come back
  7. Oct 19, 2010 at 11:59 AM
    MTgirl
    Weesa
    too bad you're so far away...
    heading to my shop tonight after work. will report back later.
  8. Oct 20, 2010 at 12:24 PM
    MTgirl
    Weesa
    alright...just got back from the tire shop and a little cruise. they rebalanced the rears, both were off. now I have more weights, not less.:( oh well, its good for now. if this doesn't last then i will be off to get the road force balancing done.
    Bad news is that the guy at the shop remembered my name this time...he always remembers my truck, never my name. I think I go there too often...:anonymous:
  9. Oct 20, 2010 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    He probably thinks you got the hots for him.................:popcorn:
  10. Oct 20, 2010 at 12:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    They're stock?
  11. Oct 20, 2010 at 12:27 PM
    MTgirl
    Weesa
    grazie!
  12. Oct 20, 2010 at 12:28 PM
    MTgirl
    Weesa
    i think he meant it as in 'nice ride'
  13. Oct 20, 2010 at 12:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    I think he meant the ones at the top of page 2.:p
  14. Oct 20, 2010 at 12:32 PM
    MTgirl
    Weesa
    most definitely not...he's like 60 or something. eeewwww....i do have standards you know!
    and put the damn popcorn away!
  15. Oct 20, 2010 at 12:33 PM
    #35
    98tacoma27
    Ben
    Not Beech Creek
    Riiiiiiiight........................:popcorn:
  16. Oct 20, 2010 at 12:48 PM
    #36
    MTgirl
    Weesa
    right what? speak up boy, don't be shy.
    well un-grazie then!
  17. Oct 20, 2010 at 12:50 PM
    #37
    98tacoma27
    Ben
    Not Beech Creek
    Boy!?!?!?! 'cuse me!!?!?!?!
  18. Oct 20, 2010 at 12:53 PM
    #38
    JLee
    Jerry
    Grass valley CA
    well then grazie from me those are mine!
  19. Oct 20, 2010 at 12:54 PM
    #39
    MTgirl
    Weesa
    okay...speak up ma'am!:D
    better?
  20. Oct 20, 2010 at 12:58 PM
    #40
    98tacoma27
    Ben
    Not Beech Creek
    Hmm, you're on thin ice Ma'am. :popcorn: :popcorn:
