Will the OEM front shocks work with spacer lift?
Discussion in '5 Lug' started by Onlydad, Jul 11, 2020.
  1. Jul 11, 2020 at 6:59 AM
    Onlydad
    Onlydad [OP] Well-Known Member
    2014 Tacoma
    Stock
    I installed a Procomp lift about 4 years ago on my 2014. All's well however it seems the front shocks have stiffened for whatever reason. It hardly moves when I sit my 250 lbs fat self on the fender and bounce. I assume it's the Bilstien shocks??
    I still have the OEM shocks, will they fit with the Procomp spacers?
    Any ideas as to why the stiffness? Seems it's only the down travel up travel is fine.
    And or if the OEM shocks will fit or should I order a new set of Bilstiens?
    Any idea will be appreciated.
  2. Jul 11, 2020 at 7:30 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    2003 5 lug 2rz
    3k into a 5 lug and it aint even LT
    Yes, you're just preloading ur stock suspension. Could go with longer ones, but not needed from what i know
