will the tires fit with the Spidertrax spacers?
Discussion in 'Wheels & Tires' started by Mike K, Aug 23, 2010.
  1. Aug 23, 2010 at 10:33 AM
    Mike K
    Mike K [OP] Member
    I read almost every topic here about tire size and wheels ... but I didn't see this one.
    Will a 285/75/17 Terra G on a stock TRD 17" fit my 2009 DC 2WD TRD Sport without rubbing if I use the Spidertrax 1.25 spacers (I already have the spacers) I am thinking since I have the spacers I can go bigger than the 265/70/17's that everyone says the largest tire? Thanks for your help. Mike :confused:
  2. Aug 23, 2010 at 1:30 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    285/75/17's are a 34" tire.
    In order to fit 33's, you need a 3" lift and to trim the fender, in addition to the wheel spacers. Fitting 34"s will be tough, but there a few people I can think of that have 35"s on just a 3" lift (RelentlessTaco and jhodge83). Check into their setups.
  3. Aug 23, 2010 at 5:33 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    Mike . 265/70/17 is The largest tire size on stock supension. if you wanna run 285 tires you will need atleast 2.5" lift but still have to trim a bit . Im in san diego now with my truck if you wanna meet to check out our cars, so Give me a call any time if still got my # .
  4. Aug 24, 2010 at 8:21 AM
    Mike K
    Mike K [OP] Member
    Thanks for the replies. Experience saves money. Appreciate it.:)
