will the wheels be ok?
Discussion in 'Wheels & Tires' started by black cx, Feb 16, 2011.
  1. Feb 16, 2011 at 2:54 PM
    black cx
    black cx [OP] Well-Known Member
    Bay Area, CA
    2010 Tacoma 4x4
    im running toyotec ulk kit
    procomps 18x9
    backspacing: 5''
    offset: 0
    tires: terra grapplers 285/65/18
    should it be ok?
  2. Feb 16, 2011 at 3:05 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    what type of pro comp wheel is it? You are going to want to go with 4.5" backspacing to help eliminate any rubbing that you may get on your UCA/cab mounts with the 285s. If they are aluminum pro comps, you should be ok.
  3. Feb 16, 2011 at 3:08 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    4.5" BS would be better, as especk said, but I've seen folks running 33's on 5.0" BS. It requires a lot of trimming and a cab mount chop.
    I assume you have a 3" lift since you plan on running 33's?
    Edit: Nevermind I see you hav the ULK now.
  4. Feb 16, 2011 at 3:08 PM
    KPT
    09 Prerunner
    Does procomp make 18" steel wheels?
  5. Feb 16, 2011 at 3:09 PM
    especk
    Erik
    Redding, CA
    oops probably not. I forgot he's goin with 18s.
  6. Feb 16, 2011 at 3:14 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
  7. Feb 16, 2011 at 3:16 PM
    KPT
    09 Prerunner
  8. Feb 16, 2011 at 3:20 PM
    JLee
    Jerry
    Bay Area NorCal
    Also the pxa-7032-8983 are 5 lug wheels.
  9. Feb 16, 2011 at 3:21 PM
    JLee
    Jerry
    Bay Area NorCal
  10. Feb 16, 2011 at 3:23 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    i have total chaos UCA's..will that help out?
    kinda too late now..mounted the tires on the wheels...yikes..
  11. Feb 16, 2011 at 3:24 PM
    JLee
    Jerry
    Bay Area NorCal
    Wheel spacers if you have rubbing issues.
  12. Feb 16, 2011 at 3:30 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    hahaha..praying that this would be okay..gonna be installed at mod day next sat..ahh
  13. Feb 16, 2011 at 3:33 PM
    JLee
    Jerry
    Bay Area NorCal
    Well we will have to wait and see if they fit.
  14. Feb 16, 2011 at 3:36 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    okay sounds good..getting nervous
  15. Feb 16, 2011 at 3:48 PM
    JLee
    Jerry
    Bay Area NorCal
    It's just rims if you rub you get some 1/2" spacers
  16. Feb 16, 2011 at 4:06 PM
    KPT
    09 Prerunner
    Wait they are the wrong bolt pattern?
  17. Feb 16, 2011 at 4:07 PM
    black cx
    Bay Area, CA
    2010 Tacoma 4x4
    no..its the correct one..i think i gave the wrong product code..but its 6 lug
  18. Feb 16, 2011 at 4:08 PM
    especk
    Erik
    Redding, CA
    haha i dont even know whats goin on here anymore
  19. Feb 16, 2011 at 4:20 PM
    JLee
    Jerry
    Bay Area NorCal
    LOL he's all good were just going to see if he rubs on the UCA's next weekend when we install the rims at mod day.
