Will these speakers fit in my 2008 double cab
Discussion in 'Audio & Video' started by Taco Lover, Nov 23, 2009.
  1. Nov 23, 2009 at 7:58 PM
    Taco Lover
    Taco Lover [OP] Active Member
    Baton Rouge, Louisiana
    08 Tacoma Double Cab 4X4 Sport (LWB) Silver
    Alpine SPS-609 6x9 in the front doors
    Alpine SPS-600 6.5 in the back doors
  2. Nov 24, 2009 at 5:27 AM
    ENIGMA206
    ENIGMA206 Well-Known Member
    Palm Bay, FL
    07 4X4 Off-Road DC
    Tunes Tonneau On-board Air Firestone Air Bags
    The 6.5" in the rear should be no problem with the standard adaptors. Should be plenty of room. The 6x9" in the front will need at least an inch spacer to get them out far enough for the window track to clear.
  3. Nov 24, 2009 at 6:04 AM
    DaytonLax14
    DaytonLax14 Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    Look into getting round speakers and adapter brackets for the front doors.
  4. Nov 24, 2009 at 6:21 AM
    virgilus11
    virgilus11 Well-Known Member
    kearny, nj
    09 sr5
    TRD supercharger,EMU 884 springs, 90000 shocks, air bags rear and TSB with EMU shocks, grillcraft mesh, Relentless front bumper,Armology rear bumper, byxenon hid's retro ,undercover lid with bike rack on top, Kenwood dnx9140,TRD cover seats
    Round speakers ??? not oval ??? Can you please explain the reason ???. I am in the process to replace my oem set up. Thank you
  5. Nov 24, 2009 at 6:29 AM
    DaytonLax14
    Corey
    Ohio
    oval speakers distort in lower bass frequencies at higher volumes much more and quicker than round speakers and a round cone is much more rigid than an oval one, which will cause distortion.
  6. Nov 24, 2009 at 6:43 AM
    ENIGMA206
    Palm Bay, FL
    07 4X4 Off-Road DC
    I'm gonna have to agree with Corey. I just put 6x9 Polk Momos in my front doors. My last truck had lower-end Polk dB series 6.5" components in the front doors. I have to admit that the 6.5" were much cleaner than the higher-end 6x9 Momos...to me of course.
  7. Nov 24, 2009 at 6:46 AM
    BIGLuke
    BIGLuke I'm a TW addict!
    Luke
    Chicago suburbs IL
    07 4X4 tacoma SR5 Double Cab Shortbed Speedwy
    There is a chance I might be wrong so if I am my bad: To my understanding if he is not getting a sub in the truck a 6x9 is a perfect option because the cone area is almost as big an 8 inch sub, which will give him a decent amount of bass to satisfy his needs. When getting a quality 6x9 a speaker an amp is a must to supply the speakers with the power they want and need. Also with a quality 6x9 that is hooked up to an amp and quality 6.5s in the back that are hooked up to an amp he should never have distortion issues as long as everything is connected right. I'm sure others will pitch in with their knowledge as well.
  8. Nov 24, 2009 at 9:12 AM
    virgilus11
    kearny, nj
    09 sr5
    Thank you for explaning.
  9. Nov 24, 2009 at 9:29 AM
    DaytonLax14
    Corey
    Ohio
    No problem. Good luck with replacing your system:)
  10. Nov 24, 2009 at 10:01 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Round > Oval speakers. Thats my personal preference.
  11. Nov 24, 2009 at 12:36 PM
    atsaubrey
    atsaubrey Dealer/Sales Rep for Sundown Audio.
    california
    blue 2007 double cab
    Sundown Audio 100.4 and 1500D, Pioneer 880PRS, Zapco Refernece 6.5" comps, 2 10" Image Dynamics IDQ, 200ft of Second Skin deadener, Kicker wire
    The oval speaker ideas are incorrect. I personally use 6x9's in both my truck and competition car. Considering the truck has taken 2nd place in IASCA SQ and the car has NUMEROUS wins in IASCA SQ including a 2nd place finish in the West Coast Regionals missing the top prize by a single point and an invite to World Finals.
  12. Nov 24, 2009 at 12:38 PM
    DaytonLax14
    Corey
    Ohio
    .....no it's not.
    It's not a matter of opinion, it's a fact.
  13. Nov 24, 2009 at 12:41 PM
    atsaubrey
    california
    Please direct me to factual information.
  14. Nov 24, 2009 at 12:47 PM
    DaytonLax14
    Corey
    Ohio
  15. Nov 24, 2009 at 1:11 PM
    atsaubrey
    california
    first of all, I do not want round speakers in my car.
    I think we need to make something very clear here, every article states "generally" a round speaker sounds better. There were several references as to the "highest end" manufacturers not building oval speakers for their high end lines. I will say Image Dynamics' high end line the XS series, includes two oval speakers in the line up. A 5x7 and a 6x9. If you call ID and ask thier recommendation for the best drivers they make the would without hesitation say the XS69 6x9 driver. I am on the ID competition team and use the XS69's in both of my vehicles. Under recomendations from ID, Eugene Kang (another team member) actually switched out his XS65 (6.5") mids to the XS57 (a OVAL 5x7) and immediatley saw his scores go up in competition. So, before pushing people away from the idea of using oval speakers you might want to listen to a good set first. :)
  16. Nov 24, 2009 at 1:18 PM
    DaytonLax14
    Corey
    Ohio
    I have had numerous oval and numerous round speakers. The cone on oval speakers is more rigid, which causes distortion at low frequencies. Almost always will an oval speaker cause more distortion than a round speaker, if comparing the same brand/model. Not to mention, speakers were just simply made to be round.
    round>oval. that is all.
  17. Nov 24, 2009 at 1:40 PM
    BIGLuke
    Luke
    Chicago suburbs IL
    atsaubrey you are correct and thank you for confirming my theory. DaytonLax14 I think you should rethink your "facts".
  18. Nov 24, 2009 at 2:00 PM
    DaytonLax14
    Corey
    Ohio
    The same to you guys. I stand by my word. Round speakers will produce a clearer sound, due to the fact that they are symetrical. The signal is disperced throughout the speaker evenly, creating a sound that is syncronized.
  19. Nov 24, 2009 at 2:03 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    yes they fit i have them in my truck i just cut out the stock speaker and bolted the 6x9 onto the stock speaker basket sounds pretty good for a cheap speaker
  20. Nov 24, 2009 at 5:03 PM
    Taco Lover
    Thanks for all the feed back. I just placed the order for my Alpine speakers. They should sound pretty good with the 4 x 50 watt Alpine amp I'm installing.
