will these tires fit my taco?
Discussion in '1st Gen. Tacomas (1995-2004)' started by krazerkoolkid, Aug 1, 2009.
  1. Aug 1, 2009 at 2:18 PM
    krazerkoolkid
    krazerkoolkid [OP] Member
    98 prerunner SR5 2WD
    coilover shcoks k&n+throttle body spacer. sub and amp
    1998 taco..
    4 16 in,6 lug with 5.5 pattern, took off a 06 silverado 33 in tires
    if not arent there wheel converters if all else fails?
  2. Aug 1, 2009 at 2:40 PM
    krazerkoolkid
    i have coilovers on the front so 2-3' lift but back is stock for now.. im not sure if this helps but the 2 front tires are 305/70/16 firestone A/Ts the rear 2 are 285/75/16 both equal to 33in,
  3. Aug 1, 2009 at 4:51 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i know the older chevy wheels had a smaller center bore than the taco.... might have some hub fitment issues...
    depending on the backspace of the wheels, you could face tire rub issues too...
  4. Aug 2, 2009 at 7:14 AM
    devilsalmostfree
    devilsalmostfree Well-Known Member
    Carl
    Loudon, Tn
    99 Tacoma 4X4, 5 spd, 2.7 ltr
    Deck plate mod, intake silencer removed, AFE Pro Dry S Air Filter, debadged, Goodyear Duratracs 265/75R16. Flowmaster knock-off muffler!
    X2, i had a 02 silverado & the wheel wouldnt go on my taco, because the smaller center bore!
  5. Aug 2, 2009 at 7:38 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x3 I had a buddy with this same issue
