Will they fit?
Discussion in 'Wheels & Tires' started by Aztacotrd, Feb 25, 2011.
  1. Feb 25, 2011 at 8:29 PM
    Aztacotrd
    Aztacotrd [OP] Well-Known Member
    Austin
    Az
    O8' V6 Prerunner Accesscab
    I've been reading about backspacing and tire size but I want to make sure that they'll fit before I actually spend the money!
    Wheels: Pro Comp 7033 -6 offset 4.75 Backspacing
    Tires: 285/70/r17 (should be a 33x11.25" tire right?)
    This will be on a 3" lift.
  2. Feb 26, 2011 at 11:23 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    4.5" backspacing would be better, but people do run 33's on 4.75" backspacing, it just requires a little more trimming is all.
  3. Feb 26, 2011 at 12:15 PM
    Aztacotrd
    Austin
    Az
    So lets say you had a rim with 3.75" backspacing it would fit better and one with 5" backspacing wouldn't fit as well?
  4. Feb 26, 2011 at 12:22 PM
    KPT
    09 Prerunner
    No the 3.75 would push the tire out pretty far and can lead to rubbing on the outer edge when turning. 4.5 has been shown to be the best balance.
