Will this 2" level my Truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rail, May 9, 2012.
  1. May 9, 2012 at 6:06 PM
    Rail
    Rail [OP] Well-Known Member
    Alabama
    2013 Tacoma Pre-Runner TRD Sport
  2. May 9, 2012 at 6:09 PM
    dad32509
    dad32509 Thinking of something clever
    Dave
    San Diego
    Blacked out 05
    5100's front and back, OME 885x's, LR UCA's, OMD rear springs, Pioneer AVH-P2300DVD, HVAC Green led's MOD, Blacked out bumper, Plastidip emblems, custom front tube bumper, 32" combo led bar, rigid duallys, otrattw switches, my own Satoshi grille, shorty antenna, Spyder LED halo headlights. csjumper2003 map/dome, 3rd brake, DTRL white/amber and parking LED's. Pelfreybilt IFS skid, Cab mount chop, sliders and rear light bar w/blitzpro 5LR dust light. Uniden CB, Magnaflow 18" exhaust, Rear tire carrier, sway bar removed, spidertrax 1.25" spacers, Wheelers 16" Alloys w/265/75r16 Goodyear DuraTracs
    :crapstorm:
    And the shit storm will begin
  3. May 9, 2012 at 6:10 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    A lot of guys will tell you not to use spacers and some will tell you its ok. It will level out the front but do your research first and look at all the options
  4. May 9, 2012 at 6:24 PM
    Rail
    Alabama
    Yeah I've been lookin and reading and :annoyed:
  5. May 9, 2012 at 6:27 PM
    zachc113
    zachc113 Well-Known Member
    I wish lifts where tht cheap. The lift i am planing on going with is the Bilstien 5100s.
  6. May 9, 2012 at 6:29 PM
    GA_TACO4x4
    GA_TACO4x4 Well-Known Member
    here 'n there
    07 DCSB 4x4
    marathon superhide max-4 seat covers, weathertechs, maglite mod, 20% tint, 2" leveling kit, leaf spring tsb.
    i have a similar ebay 2" leveling kit on my truck. rides fine, no alignment issues. i think the rear is about 1" higher which is perfect for when I tow stuff. and you cant tell the rear is higher unless you put a measuring tape to it
  7. May 9, 2012 at 6:30 PM
    Rail
    Alabama
  8. May 9, 2012 at 6:32 PM
    Rail
    Alabama
    I just want the front up for looks not for bigger tires so I may try the 2". If it's working for you must be ok.
  9. May 9, 2012 at 6:35 PM
    dad32509
    Dave
    San Diego
    Blacked out 05
    Yeah that was my plan.....then it turned into needing new coils cause stock is too stiff, then uca cause I want the alignment to be perfect, then new tires cause stock now looks to small.......
  10. May 9, 2012 at 9:33 PM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    I did 2.5 spacer with no rear TSB or any other adjustment to it. My front-end is now squeaky on bumps which is really annoying at times. I'm not sure if getting bilsteins would help my situation or not, but I may opt for them at a later time. The ride is fine, I only drove the truck stock for a couple weeks before I had the spacer put on, and couldn't tell a difference in the "ride" after having it installed. I could definitely tell a difference when I sat in the truck though. The truck is a little high on the front, I dont have any measurements handy..
  11. May 10, 2012 at 2:15 PM
    Rail
    Alabama
    Thanks for the reply and I think I'll try the 2 inch on top of the strut and see what happens.
