Will this fit?
Discussion in 'Wheels & Tires' started by airsoft_warrior, Jan 1, 2010.
  1. Jan 1, 2010 at 8:26 AM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I am running 265/70/16 for the stock rugged tires that came with the off road package. I have the suspension tsb and the 5100's in the front. I was looking at either dune grapplers or the trail grapplers in 285/75/16. will they fit. I know height wise they will but what about going from a 70 to a 75?
  2. Jan 1, 2010 at 8:27 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    You'll have some minor rubbing if you set the Bilstein 5100's at 2.5''.
  3. Jan 1, 2010 at 8:28 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    This^:D
  4. Jan 1, 2010 at 8:31 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Yes they are set at 2.5. How can I prevent rubbing. and will it hurt the truck or tires?
  5. Jan 1, 2010 at 8:33 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Take off mud flaps, trim the wheel well. backspacing on rims?
  6. Jan 1, 2010 at 8:36 AM
    Incognito
    VA
    Take the mud flaps off if necessary, trim some, get a wheel with a 4.5'' backspacing or less.
    EDIT: What Jigzor said.
  7. Jan 1, 2010 at 8:37 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    What is back spacing? ( I feel like a noob)
  8. Jan 1, 2010 at 8:40 AM
    Jigzor
    Pennsylvania
    17 DCSB Silver Sky
    Backspacing is the distance from the mounting pad of the wheel to the inside edge of the wheel. The mounting pad of the wheel is where the pad seats up against the hub.
    Like Colton stated, 4.5" would be good.
  9. Jan 1, 2010 at 8:42 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Ok. Well I am on a limited budget so new wheels right now is outta the question. I dont know what the rugged edition rims have.
