Will this level my truck?
Discussion in 'Suspension' started by pivey14, Jan 11, 2013.
  1. Jan 11, 2013 at 10:47 AM
    pivey14
    pivey14 [OP] I'm A Grinder
    Patrick
    Baton Rouge, LA
    '11 DC Base PreRunner
    See Build Thread
    1.5 TSB AAL (Rear 5100's).........I only have 3 leafs right now.
    Bilstein 5100's @ .85
    Eibach Coils
    ^^^will this be completely level?^^^
    ***If not, how can I make it level, but keeping it under 3" so I don't have to purchase UCA's.***
  2. Jan 11, 2013 at 10:56 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    yes and add a small lift if i'm not mistaken, around 1.75 up front if you set the billies at .85.(with eibach) glad you chose the springs. less preload on your struts
  3. Jan 11, 2013 at 10:57 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    Yea, that's exactly what I'm looking for. Thanks
  4. Jan 11, 2013 at 10:59 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    Shouldn't it be more? I thought the Eibach coils added 1.6" + 85" (billies) = (total) 2.45 (2.5 rounded)
  5. Jan 11, 2013 at 11:02 AM
    boardude
    boardude BOOMSHAKALAKA
    Kris
    Tucson, Arizona
    '15 Tundra TRD Pro Inferno
    A Yota with more cowbell
    I thought the Eibachs gave a lift of 1.6" just themselves.. so 1.6 + .85 setting would sit around 2.5" up front.
    Edit: The OP beat me
  6. Jan 11, 2013 at 11:03 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    no, but if you set your strut to the next setting, 1.75, and added the eibach, then it would be the 2.5. eibach adds .85. not the billies. billies are what you set them to. i think you just have it backwards.
  7. Jan 11, 2013 at 11:05 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    billies @0 plus eibach =.85 lift
    billies at .85 plus eibach = 1.6-1.7 lift
    billies at 1.75 plus eibach =2.5 lift
    .....i think this is right,
  8. Jan 11, 2013 at 11:08 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    I just looked at the toytech website and it said Eibachs give you 1.6". Can anyone confirm this 100%?
  9. Jan 11, 2013 at 11:08 AM
    boardude
    Kris
    Tucson, Arizona
  10. Jan 11, 2013 at 11:10 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    Great minds think alike :cheers:
  11. Jan 11, 2013 at 11:11 AM
    Taco Dan
    Dan
    Tuscaloosa, AL
    ok i was wrong. lol idk lift world is so confusing. im saving up for the OME kit with dakars
  12. Jan 11, 2013 at 11:12 AM
    boardude
    Kris
    Tucson, Arizona
    Does the 1.5 TSB AAL work with leaf packs without the TSB leaf??
  13. Jan 11, 2013 at 11:15 AM
    boardude
    Kris
    Tucson, Arizona
    Yeah too many lift options. I have the OME 885x and am extremely happy with the result and quality of ride!
  14. Jan 11, 2013 at 11:16 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    That's what I'm wondering
  15. Jan 11, 2013 at 11:18 AM
    boardude
    Kris
    Tucson, Arizona
    I dont think it does.. Toytec sells a Non-TSB AAL. Or you could try to get the TSB which would add another .75 - 1 in the rear
  16. Jan 11, 2013 at 11:20 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    I'm just trying to completely level it but also add a could of inches. I want to keep it under 3" so that I don't have to deal with UCA's. Any suggestions?
    ETA: I don't want spacers or spindles haha
  17. Jan 11, 2013 at 11:27 AM
    boardude
    Kris
    Tucson, Arizona
    I think the 1.5 AAL and the Eibachs / billies @ .85 will do the trick.
    Although your a regular cab so I think you'll get a little more lift too
  18. Jan 11, 2013 at 11:32 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    I'm a double cab
    .....or atleast I think I am. DC = 4 door, correct?
  19. Jan 11, 2013 at 11:38 AM
    boardude
    Kris
    Tucson, Arizona
    Ha - Yeah DC = 4 doors. Your little thing under your avatar says regular cab.
    Then yes I would go with the eibachs @ .85 with a 1.5 AAL. This should give about 2.5" lift and "level" (which is defined very differently in here)
  20. Jan 11, 2013 at 11:43 AM
    pivey14
    Patrick
    Baton Rouge, LA
    See Build Thread
    Sorry. need to fix that
    Perfect! my definition of level is the same length (front and back) from center cap to top of the wheel well. Same for you?
