Will this Magnaflow fit?
Discussion in '1st Gen. Tacomas (1995-2004)' started by taco52, Jun 12, 2012.
  1. Jun 12, 2012 at 4:10 PM
    taco52
    taco52 [OP] Well-Known Member
    01 SR5 v6 5speed 4x4
  2. Jun 12, 2012 at 7:14 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    Mine is a 14" center offset...it works I guess. I had some issues with it staying clamped after flexing it the first few times. I ended up getting ultra-anal retentive and making sure that the muffler was perfectly centered between the intermediate pipe and tailpipe, then clamping. I had it within 1/16" of being perfectly centered and it hasn't came loose again. That's the only issue I've had.
  3. Jun 13, 2012 at 12:36 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    Either way will work... a muffler shop can make either application work. Stock however is offset in and center out which seems to be what most people go with when they get aftermarket mufflers most likely for the ease of install.
    I went with an offset/offset design as I wanted the muffler to hang a little higher which also allowed the custom tailpipe I had made to be even more hidden behind the frame rail.
  4. Jun 13, 2012 at 5:19 PM
    taco52
    thankyou for the info^^
  5. Jun 14, 2012 at 3:43 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    do you have a BMW ?? :confused:
    I'v got a 18" offset in/center out and mounted it vertically. fits great and sound good imo
