Will this wheel fit?
Discussion in 'Wheels & Tires' started by kylemob, May 15, 2008.
  1. May 15, 2008 at 1:22 PM
    kylemob
    kylemob [OP] The Jacobite
    Willamette Valley, Oregon
    2008 Tacoma 4x4
    Workin on it...
    It's a stock 16" set off a Tacoma. I'm going to be putting them on my 2008 Tacoma (after a nice black powder-coating) and adding my 265/75/r16s to them. The guy THINKS it came off a '98. Here's a pic so you know which wheel. I don't know the backspacing or offset on these and would like to know if anyone here knows before I make the hour long drive to check fitment. Thanks a ton for your help.
    ps, anyone know if this is a 16x7 or a 16x8? Because that would be a deal-maker or breaker also.
  2. May 15, 2008 at 1:47 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i think the thing to watch out for will be the rims rubbing on the calipers. depending on the backspacing, u might have to run spacers to have them out enough to not touch.
  3. May 15, 2008 at 2:32 PM
    kylemob
    2008 Tacoma 4x4
    Workin on it...
    Ya, I've heard that is a big problem with the new Tacos. Does anyone know for sure if this particular wheel is going to be an issue on fitment? I'm fighting with myself over buying these wheels (if they will work) or painting my stock steelies black since it would be cheaper. I'm getting married so I've turned into a penny-pincher.
  4. May 18, 2008 at 3:35 PM
    trailinTaco
    trailinTaco Well-Known Member
    Bel Air, MD
    2000 Tacoma SR5 TRD 3.4L 4x4
    3 inch suspension lift, 33 inch bfgoodrich mud terrain tires, toytech diff drop, Procomp alloy wheels, hella fog lights, black projector headlights with 8000k HID's, blacked out tail lights, two 12 inch subs, 20% tint, pioneer head unit and speakers
    you might want to double check the size of the rim. I had those same wheels on my 2000 and they were 15 inchs
  5. May 18, 2008 at 3:44 PM
    kylemob
    2008 Tacoma 4x4
    Workin on it...
    Thank you, I will definitely check that out.
