Will this wheel my Truck?
Discussion in 'Wheels & Tires' started by raswank, Jan 18, 2011.
  1. Jan 18, 2011 at 2:22 PM
    raswank
    raswank [OP] Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Will this wheel fit my truck and it is 6 on 5.5
    4.500 in.
    Beadlock Functional
    No Beadlock Included
    No Center Bore Diameter (in)
    4.251 in. Center Bore Diameter (mm)
    108.00mm Center Cap Included
    Yes Hub Centric
    No Load Rating (lbs)
    2,200 lbs. Lug Nut Seat Style
    Conical seat - 60 degree Manufacturers Wheel Series
    American Racing ATX Artillery Series Offset
    -12.00mm Primary Wheel Color
    Chrome Quantity
    Sold individually. Valve Stems Included
    No Wheel Construction
    1-piece Wheel Diameter
    17 in. Wheel Finish
    Chrome Wheel Material
    Aluminum Wheel Width (in)
    9.000 in.
  2. Jan 18, 2011 at 2:30 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Will this wheel your truck? :confused:
    I think you choose to wheel your truck, it doesn't just do it on its own.
    As for fitment, the specs look good, just make sure it's 6 on 5.5 bolt pattern.
  3. Jan 18, 2011 at 2:38 PM
    raswank
    Rick
    Auburn,Ma
    No spacers or anything needed correct. It will be going on in the summer after the new Eibachs, 5100's, and 1.5 AAL
  4. Jan 18, 2011 at 2:41 PM
    KPT
    09 Prerunner
    What size tires do you plan to run?
  5. Jan 18, 2011 at 2:48 PM
    raswank
    Rick
    Auburn,Ma
    MY 265/70/17 Geolanders
  6. Jan 18, 2011 at 2:51 PM
    KPT
    09 Prerunner
    Yep, should fit no problem with the 4.5" backspacing.
  7. Jan 18, 2011 at 2:59 PM
    raswank
    Rick
    Auburn,Ma
    My stock 17 sport wheels are still going to fit as well correct for winter? After the upgrades
  8. Jan 18, 2011 at 3:08 PM
    KPT
    09 Prerunner
    yes
  9. Jan 18, 2011 at 3:09 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Ya you'll have no problems. I'd like to see more pics of your truck, I'm changing my setup to what you currently have and I even started a thread on it to see trucks with that setup.
  10. Jan 18, 2011 at 3:14 PM
    raswank
    Rick
    Auburn,Ma
    Get my upgrades next week. Eibachs, rear 5100's, 1/4 inch drivers side spacer. 1.5 AAL. carriage bearing drop kit, and shims. I will let you know when it is in.
