Will this work
Discussion in 'Suspension' started by Pfirestone01, Apr 19, 2012.
  1. Apr 19, 2012 at 1:47 PM
    Pfirestone01
    Pfirestone01 [OP] Member
    Tennessee
    2012 trd off road 4x4
    Trd cat back exhaust, westin side steps, trd grill badge
    I have a 2012 trd off rd dbl cab and was wondering if I got the blisten 5100's up front And put the toyotec 2" aal in the rear would this work without any problems or would I need to get anything else. I had also looked at the Blisten adjustable lift kit on toyotecs web site. Just wonder if it would be worth the extra $$$ or if this would work ok
  2. Apr 19, 2012 at 1:49 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    It will work.
  3. Apr 19, 2012 at 1:49 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yes this will work and a lot of people on here have that setup. Do you plan on doing a lot of off-roading?
  4. Apr 19, 2012 at 2:08 PM
    Pfirestone01
    Tennessee
    No not in the near future I have a 04 for off roading right now
  5. Apr 19, 2012 at 2:11 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh okay. Yeah that lift should be fine for you.
  6. Apr 19, 2012 at 2:14 PM
    Pfirestone01
    Tennessee
    Ok thanks. And I don't need to buy anything else correct?
  7. Apr 19, 2012 at 2:18 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    No you should be good to go. What are you planning on setting your 5100's at?
  8. Apr 19, 2012 at 2:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You should get rear shocks to acomodate the extra rear lift.
  9. Apr 19, 2012 at 2:27 PM
    Pfirestone01
    Tennessee
    I don't really know to be honest I was thInking 1.25 but what would be
    Best with the 2" aal. Im new to this so idk what would be best
  10. Apr 19, 2012 at 2:29 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Depends on how you want your truck to sit. Since your getting a 2" AAL your gonna want to set it at 2.5" to level it out and even at that the rear end will stick up about a half inch higher then the front.
  11. Apr 19, 2012 at 2:35 PM
    Pfirestone01
    Tennessee
    Ok so how much higher does the rear end set up right now stock? Or would I be better off getting a 1.5 aal to get it to be level with the front set at 1.25
  12. Apr 19, 2012 at 2:46 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    You could go with a 1.5" AAL and set your 5100's at 2.5"s then you should be pretty darn level. 1.25" with a 1.5' AAL, your still going to sit rear end high.
  13. Apr 19, 2012 at 2:49 PM
    Pfirestone01
    Tennessee
    Ok thanks that's what I will do I appreciate your help.
  14. Apr 19, 2012 at 2:50 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    No problem.
