Will wheel offset help tire clearance ?
Discussion in 'Wheels & Tires' started by Trail Cat, Oct 18, 2013.
  1. Oct 18, 2013 at 8:41 PM
    Trail Cat
    Trail Cat [OP] Well-Known Member
    Florida to NC
    2013 TRD Sport 4x4
    Bull Bar - TRD Exhaust - Predator Side Steps - Alarm - Anytime On Fog Lights mod - OBD UltraGauge II - LED Dome & Map Lights - LED Aux BackUp Lights - LED DRL - Gate Keeper mod - TRD bed Cup Holder & Bottle Opener - Center Console Lock mod - WeatherTech Mats - Kicker Hideaway - Rear Door Speakers - Spare Tire Extension Valve mod - Tail gate 3rd Brake Light Bar - Proline Wheels - Rear Diff Breather mod (left rear tail light area) - "Florida Tacoma's" sticker - BFG A/T KO2 tires -
    Hey guys, I am thinking about replacing my stock 265/65/17 tires for some 265/70/17 Goodyear, Wrangler All-Terrain Adventures. I am also replacing my stock wheels which I understand has an offset of plus 15 to plus 25. I am not sure of the exact stock offset. However, the new wheels I want are still 17” and have a zero offset.
    My concern is by increasing the tire sizes from 265/65 to 265/70 will there be a clearance problems?
    Secondly if there is any problem should the wheel with a zero offset help?
    Thanks in advance !!
  2. Oct 21, 2013 at 10:57 AM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    What year is your truck?
  3. Oct 23, 2013 at 7:12 PM
    Trail Cat
    Florida to NC
    2013 TRD Sport 4x4
    Thanks for your reply and to answer your question; My truck is a 2013 Tacoma TRD Sport 2 door Access Cab. It has the Stock 17" wheel and came with 265/65/17 Bridgestone tires.
    I wanted to upgrade the tires to All Terrain and also get the Dick Cepek DC2 wheels but those wheels had an off set of -12 and I was told to use these wheels on my truck it would need to be lifted or leveled. I don’t want to do a lift at this time. So I found some wheels at Pep Boys that look very similar to the DC2, they are; Pep Boys 8x17 ProLine MA 1211 that has a zero (0) offset.
    My first question (concern) is tires, keeping the 17" stock wheels and up grading the tires only from 265/65 to 265/70 any issues?
    Secondly, if I change my stock 17” wheels for the Pep Boys wheels with the zero offset will this cause any problems, future damage, harm in any way?
    Finally will the 265/70/17 tires and Pep Boys wheels with 0 offset work 100% on my truck?
  4. Oct 24, 2013 at 11:39 AM
    Discount Tire
    Arizona, USA
    Thank you for the additional information.
    The 265/70-17 (31.6" tall) tire size is the maximum size you'll want to run with stock suspension but it will work with the factory wheels (17x7.5 EET+30) as well as the 17x8 ET0 wheels you noted. The 17x8 ET0 wheels will sit about 1.5" further out towards the fender when compared to where the factory wheels sit now which means you may have to trim the mud flaps with the 265/70-17 tires.
  5. Oct 25, 2013 at 7:01 AM
    Trail Cat
    Florida to NC
    2013 TRD Sport 4x4
    Thanks very much for the info !!!
  6. Oct 25, 2013 at 7:57 AM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Assuming the calculations above are correct, I would agree that pushing your wheel outward 1.5" creates the likelihood that you will get some tire rub when nearing full turn. Have your dremmel ready.
