Winch mount in the bed of the truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seang, Mar 11, 2022.
  1. Mar 11, 2022 at 11:54 AM
    seang
    seang [OP] Eternal Noob
    TX
    17 White Off Road
    that has been under consideration as well, but I just had an idea.
  2. Mar 11, 2022 at 11:57 AM
    seang
    TX
    17 White Off Road
    Kayak fishing is why i own this truck. Its not like it wont drive right, affect gas mileage, or some of the other stuff ive done. heh.
    Speedbird likes this.
  3. Mar 11, 2022 at 11:59 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    You do you man, we are just throwing out alternate solutions you may not have thought of. Ones that dont require drilling holes and running wires :notsure:
    seang[QUOTED][OP] likes this.
  4. Mar 11, 2022 at 12:02 PM
    seang
    TX
    17 White Off Road
    And i appreciate that!
    Im not trying to be nasty about it, sorry if i came across like that.
    TartanEagle likes this.
  5. Mar 11, 2022 at 12:11 PM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    If you do go this route, you can add a front receiver too. Then you'll have actual winching in either direction - and for more than just the kayak.
    Use Anderson plugs for the power coming off the battery in the front; then have the mates on the winch itself and on an extension cord (HD jumper cables) long enough to reach the rear.
    If you think you'll ever winch the truck up a hill -or- if you know you'll never pull more than 1,000 pounds with it; chose your front receiver accordingly.
    soundman98 likes this.
  6. Mar 11, 2022 at 12:15 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Another thing of note is that it is possible to install a front bed rail which you could mount a pulley or ultra-light winch to.
    https://www.tacomaworld.com/threads/front-bed-rail.456077/
    I’m not positive this would be strong enough as I’ve never done anything like you have, but I have used the bed rails multiple times to tie down furniture and dirt bikes. In all those cases I was using multiple attachment points. I think the Toyota rates each rail at 200 lbs. it’s in the manual.
  7. Mar 11, 2022 at 12:21 PM
    Coldfuzion
    Coldfuzion Active Member
    Andrew
    2018 Beige Tacoma TRD Sport 4x4
    Prinsu Rack, more to come
    Why not go the other route and just add a snorkel to the truck and drive it down into the water. Would make loading the kayak easier as well, floating it into the bed. Snorkel and some breathers and your golden.
  8. Mar 11, 2022 at 12:22 PM
    gudujarlson
    Minnesota
    That sounds a lot more fun. Lol
  9. Mar 11, 2022 at 8:12 PM
    rick carpenter
    rick carpenter Well-Known Member
    Rick
    Huntsville, East Texas
    2019 SR5 2wd v6 DCLB for the win!
    OP, can you pull a rope standing still half the weight of the kayak plus whatever dragging friction you encounter? If so, check out a 2:1 pulley system. Run a chain between two d-rings in the front bed bolts. Attach the rope and pulleys like the illustration to the chain. Attach the lightest possible pull chain to the kayak. From the moving pulley, attach a rope with a hook hooked onto the pull chain. Pull the kayak out till you use up the rope, detach the hook on the pull chain and let the rope back out, reattach the hook and pull some more. Lather, rinse, repeat til you get the kayak to the boat.
    https://www.ropebook.com/wp-content/uploads/2019/07/pulley-2-1-150x150.jpg
  10. Mar 11, 2022 at 9:20 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Any ideas who makes the mount in the upper picture?
  11. Mar 11, 2022 at 9:33 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Thats a custom made one. No one really makes them for our trucks as there is little market, but just enough of a market you can get universal ones like this that people use for pulling ATVs or dead animals up a ramp.
    https://www.discountramps.com/toyloader-ld/p/Toyloader-LD/
  12. Mar 11, 2022 at 10:19 PM
    MARSHBUSTER
    Jim
    Alamogordo NM
    I have a headache rack in my Tacoma already for pulling Elk into the bed I was wanting something for my F-150. Thank You for the info!!!
  13. Mar 12, 2022 at 9:43 AM
    seang
    TX
    17 White Off Road
    That is a pretty darn good option right there. Its a little pricey though.
    Did some research and found i could assemble one of those with some aluminum extrusion and a few angle joints at about 1/5 the cost.
    Should be easy enough to mount a winch to it.
    https://www.tnutz.com/product/ex-20...n=61&attribute_pa_fractional-length=0-500-1-2
    https://www.tnutz.com/product/cb-010-j/
    mquibble likes this.
  14. Mar 12, 2022 at 9:55 AM
    5nahalf
    Erik
    Minnesota
    Oh for sure you can make your own with available premade parts for much cheaper. Thats how I feel about 99% of the bed bars that companies on here sell for $500+. Take these bed bars for example. They sell for $525.00 plus shipping. Its premade extrusion thats cut to length, then 4 sheets of metal bent 2 times each on a break. There is no engineering or design that warrants that price. I made my bed bars for for $60 (they are steel)
    Front sight and mquibble like this.
  15. Mar 12, 2022 at 10:02 AM
    #35
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    This would be awesome for loading (light) motorcycles and probably safer than running them up on the clutch
  16. Mar 12, 2022 at 10:25 AM
    #36
    seang
    TX
    17 White Off Road
    Did you make those sheet metal mounts, or source them somewhere?
  17. Mar 12, 2022 at 10:37 AM
    #37
    5nahalf
    Erik
    Minnesota
    Those are premade by billy bars for $525. Here are the ones I made for $60. The rack is a yakima skinny warrior knock off, and the ski rack is also a yakima knock off.
  18. Mar 13, 2022 at 6:30 AM
    #38
    Speedbird
    Speedbird Well-Known Member
    Fort Couch
    2017 TRD-OR
    Benny blanco likes this.
  19. Mar 13, 2022 at 6:44 AM
    #39
    seang
    TX
    17 White Off Road
  20. Mar 13, 2022 at 8:47 AM
    #40
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    Why not just use good old blue steel (California truck rope)? It’s amazing what can be accomplished with a long length of line, no need to drag it behind you, just haul it up with your arms. You can utilize a bed cleat to assist you as well.
    seang[OP] likes this.
