winch mount, wich with 3." lift change out uca ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXPROMAN, Mar 1, 2013.
  1. Mar 1, 2013 at 6:24 PM
    TXPROMAN
    TXPROMAN [OP] Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    If I install a 46-21605 westin max winch mounting tray and a 68 lb. winch on my 2012 tacoma . And add a 3." lift kit. Do I have to change out the uca ?
  2. Mar 1, 2013 at 6:25 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    What kind of lift you gunna get?
  3. Mar 1, 2013 at 6:35 PM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
  4. Mar 1, 2013 at 6:44 PM
    Blackshirts
    TX
    Stuff
    It would be wise to change out the UCAs.
    Also how much weight are those coils rated to carry?
  5. Mar 1, 2013 at 7:35 PM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    700lbs.
    I had that kit... up until about 3 weeks ago when I changed it out for OME shocks all around, OME 885's, and the Icon 3 leaf pack. I would highly recommned going this route as well. My procomp kit began to sag up front, giving me less than 3" of lift. After the swap... it was clear how much they had sagged and the ride now is much improved.
    Also, yes.. you'll want new uca's. Your caster will be out somewhat making your tires wear uneven and the truck to "wander"
  6. Mar 1, 2013 at 7:47 PM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    I did look into the ome. And others. I seen on the forums if you go with 2.5" lift you dont need a uca? So with the winch and bumpper the 3." may drop to to 2.5?
  7. Mar 1, 2013 at 7:52 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Yes. But you will be straining the front coil... thus making it sag, maybe even more than what it did for me.
    The 886's are made for plate bumpers/winch.
  8. Mar 1, 2013 at 7:54 PM
    tacomacrzy09
    tacomacrzy09 New Member
    Santa Clarita
    09 TRD Sport Debadged
    Tinted lights all around, CAI, 3" lift in front and 2" in back, HID lights, TRD exhaust
    I have that same lift on my '09 now and I had to change out the UCA because the outside edge of my tires were waring really bad. I would recommend that you change out the UCAs. I went with the www.Downsouthmotorsports.com ones and have love them, they are great.
  9. Mar 2, 2013 at 7:45 AM
    TXPROMAN
    Martin
    NY
    2012 TX PRO TACOMA
    Old Man Emc complete kit for the tacoma has 2 inches of suspension lift. From your link. Do you still have to change out uca with this also?
