Wind and road noise reduction solution by 15db or so
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BaciChef, Oct 12, 2021.
  1. Oct 12, 2021 at 6:13 PM
    BaciChef
    BaciChef [OP] Member
    2021 Toyota Tacoma SR 5
    HI all
    I've been racking my brain for a way other than more weather-stripping to reduce the excess wind noise and road noise on my brand new 2021 Tacoma that has been "leaking" through in the cab. Needless to say, I ended installing additional weather-stripping as the only other real option appears to be true sound proofing and I have no intention or desire to tear apart my new Tacoma to do that.
    My simple fix has been to install additional weather-stripping I purchased on Amazon. It is 0.47" h x 0.55" wide. A 20' roll was enough. I cleaned the interior of the body frame from the top of the front bolt above the door hinge with 91% alcohol and let it dry. This while I warmed up the weather-stripping in the sun. The doors require just a bit more pull to close tightly now, but that will become the norm. I did not do a perfect job, but such is life, the noise is better than it was so I'm happy. I used my sound meter to verify the improvement btw. I would suggest a the Taco Marine weather-stripping or another high quality weather-stripping. I've returned 4 unsatisfactory brands because they were crap so be selective. As a great example of improvement. I can now listen to the radio at a volume level of 15 instead of 25. To me, this improvement is huge. Feel free to message me if you have any questions.
  2. Oct 12, 2021 at 6:27 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Interesting, I didn’t realize this method worked so well. A cheaper alternative to sound proofing
    TheSlickGoose and japjoe7 like this.
  3. Oct 12, 2021 at 6:30 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Guess I must be "Old School" - buy a truck and expect the interior of the cab to be as quiet as an Avalon?
    Works for me as-is.
    hangun61, 02Duck, BoomerGVNG and 17 others like this.
  4. Oct 12, 2021 at 6:34 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    15dB is a lot. Very nice
    Abject4x4, mrbetelman and su.b.rat like this.
  5. Oct 12, 2021 at 6:36 PM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    Good stuff man, care to drop the link to the exact stuff you used?
  6. Oct 12, 2021 at 6:50 PM
    BaciChef
  7. Oct 12, 2021 at 6:59 PM
    BaciChef
    CY Yankee, I have no expectations that the truck will be an Avalon. Maybe my Tacoma has an issue some other Tacomas don’t have, maybe not. Having had a number of Tacoma’s over the years, my new one has more wind noise than any of my other ones. No sense in trying to ask the dealer to investigate it, better luck finding aliens.I just wanted to be able to have a conversation with my friends or family while also have some music playing on low volume. I posted because I know other new Tacoma owners are having the same challenges. So it’s an easy remedy and everyone I know who has spent $35 and 30 minutes is satisfied. Have a great evening
  8. Oct 12, 2021 at 7:03 PM
    Scottysan
    Scottysan Well-Known Member
    Outstanding! simple. cheap. effective.
    Thanks for sharing!
    drvn and kgilly like this.
  9. Oct 12, 2021 at 7:45 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Just hit 3k with my new TRD OR and indeed have noticed a bit of road noise that would be cool to lose. Thanks for the heads-up!
  10. Oct 12, 2021 at 8:16 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    I have to say, this truck (2018 SR 2.7) is a lot louder than my 2003 that I used to have. I do have the Extended Cab now (I had a Double Cab 3.4 before) not sure if that makes a difference or not but I might give this a try as I really don’t want to tear into my truck either. They don’t make these trucks like they used to for sure. I’m still loving this truck so far tho. :thumbsup: Thanks for the tip!
    Slippers and davidstacoma like this.
  11. Oct 12, 2021 at 8:28 PM
    CT Yankee
    CT
    I DO get it (believe it or not). But my outlook is different I guess.
    Starting with a Chevy LUV (POS) -> 1989 Toyota pickup ->1998 Tacoma -> 2006 Tacoma TRD -> 2021 TRD OR AC.
    Each step was an improvement.
    The '06 and now the '21 was/is my sanctuary. The wind noise is inconsequential to me.
    I'm sure others feel differently.
    TDImark and outdoor frenzy like this.
  12. Oct 12, 2021 at 8:38 PM
    1Crusader
    1Crusader Well-Known Member
    2020 SR5
    Nice job!
    Will try this on my Taco soon enough.
  13. Oct 12, 2021 at 8:59 PM
    Formidable
    Formidable Well-Known Member
    2017 TRD PRO 6MT
    Wow I thought the wind noise was normal for this truck. Will give this a try. Thanks for the link!
    drvn likes this.
  14. Oct 13, 2021 at 3:56 AM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    These trucks have barely any insulation and transmit lots of road noise. Especially over 55mph with bigger tires. Again my soft top JK on E rated 35s is quieter inside than my taco at highway speeds. Which makes no sense since the roof is a tent
    deuceb likes this.
  15. Oct 13, 2021 at 4:11 AM
    Scottyskywalker
    Scottyskywalker Well-Known Member
    Scott
    Kantukee
    2020 Silver Sky SR V6 4X4 SX
    RCI sliders, RCI front skid, RCI trans skid, Bridgestone Revo 3 AT, OTT tune, Fox 2.0 rear, Front Summo springs, Truxport roll up bed cover, Tekonsha P3, Meso total tails, rear diff breather relocate. JCW front bumper, Apex 12k winch, bar light. Alpine ILX 507, Kicker DX speakers, amber grill light bar, yellow LED fogs, LED headlights, bed mat, bed lights, front camera, rock lights, dash cam, seat jackers, recovery gear, Overland Equipment Aux fuse kit, C4 bumber braces.
    I found most of the cabin noise in my 2020 Access cab was coming from the back cab wall, specifically the two vents. I used $30 of sound deadening sheets to cover the back wall, placed breathable foam in the vents and a pool noodle between the cab and bed below the vents to block some of the road noise from reaching the vents.
    I only re-installed the panel leaving the jump seats and head rest out. Truck is much quieter now.
  16. Oct 13, 2021 at 7:19 AM
    BaciChef
    Scottyskywalker, Great info, if I still need to improve even more I will definitely follow your lead as well. Thanks for the great information.
    sharkytowers likes this.
  17. Oct 13, 2021 at 7:25 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I put a roof rack on and it was a little quieter. Sold the rack now it's a little louder. Crazy stuff. Doesn't really bother me either way, I usually have the radio on.
  18. Oct 13, 2021 at 7:25 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If you live in a very cold climate, you can see where the air leaks are on the truck when the inside of the truck is humid (snow melt in the floor mats)
    As you drive, the humid air goes out the air leaks, and then instantly freezes to the body of the truck. The result is small white crystalized patterns. I have found on my truck, the only places are the top of the doors between the front and rear door. This is exactly where your new seal would seal it up.
    Nice work!
  19. Oct 13, 2021 at 8:45 AM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    Any reason you stopped where you did, just behind the top of the window? Is there a problem with continuing back down the door jamb? I haven't looked at it yet.
    mike s, drvn and BaciChef[OP] like this.
  20. Oct 13, 2021 at 9:24 AM
    auk
    auk Well-Known Member
    Dave
    I gotta go get me a noodle, this sounds like an awesome idea.
    sharkytowers and grogorat like this.
