Wind and road noise reduction solution by 15db or so
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BaciChef, Oct 12, 2021.
  1. Nov 17, 2021 at 12:37 PM
    #101
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Thanks! Okay, last question (I think). It looks like you secured it with plastic push-pin style buttons. Or is it something else? The link you posted for the material said it was non-adhesive. I'm trying to find out how I can secure it safely to the hood.
  2. Nov 17, 2021 at 1:18 PM
    #102
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I used a combo of the plastic push-pin style ones (I found some that said they were underhood temp rated) in the center and I used metal ones from the same place I bought the liner for the corners. The ones in the center I used existing holes in the hood. The ones in the corners I drilled new holes in some of the cross members on the hood.
  3. Nov 17, 2021 at 4:52 PM
    #103
    Impoy47
    Impoy47 YOLO-HA!
    R-nel #KN6UYM
    East bay Tri Valley, Ca.
    Xwing T-19 Pro Voodoo Fighter
    Just adding another pic from the outside. As you can see, the rubber trim seals along the edge of the panel.. knowing now, it would be easier to install when sunroof is open..
    drvn likes this.
  4. Nov 17, 2021 at 5:45 PM
    #104
    TheAredub
    TheAredub Well-Known Member
    USA
    AG Taco Pro - Sold
    Mods - Yep, a few ...
    I did this mod (front and rear doors) over the weekend and finally got my Tacoma out on the freeway today. Have to say that I didn’t notice much, if any difference in the interior noise level. It was worth a shot though.
    MountainManGuy likes this.
  5. Nov 19, 2021 at 2:29 PM
    #105
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Probably helps with those who more modded and with louder MT tires.
  6. Nov 20, 2021 at 1:52 AM
    #106
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I used a round black pipe insulation aka pool noodle between the cab and the bed a few years ago. I just bought a roll of the weatherstripping this past week, did the truck and heard no difference. The doors were hard to shut, and I think this was putting too much stress on the doors. I removed the weatherstripping after a few days and again it sounded the same. My truck is very quiet to begin with but for $30 I had to at least try it. One thing I had done when the Rockford amp and sub went in was dynomatting the back panel and under the carpet and the pool noodle.
  7. Nov 23, 2021 at 6:21 AM
    #107
    BudLoomis
    BudLoomis Well-Known Member
    Colorado
    2018 TRD Off-road
    Toytec Aluma Series 2.0 (2.5" x 3.5" lift), JBA UCA, Deaver stage 3 Leaf pack, CMC, Viair OBA set-up, KBVOODOO mid rack, Roofnest Condor RTT, CaliRaised Premium Roof Rack w/ 360 lighting, Custom Bed box w/ camp stove built in
    I did this mod and definitely noticed a difference. For $30 and 10 minutes of time, I think it's worth it. Also, the pool noodle over the rear seat vents also helps a ton.
  8. Nov 23, 2021 at 6:44 AM
    #108
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    Could you show more photos of where you placed the weatherstripping
    cryptolime likes this.
  9. Nov 23, 2021 at 9:12 AM
    #109
    Micwithoutthek
    Micwithoutthek Well-Known Member
    Mic
    2019 Toyota Tacoma TRD Offroad CEMENT
    Followed this today and it does make a difference. Pretty good to do after a lift and new tires, now my sound is back down to "NORMAL" levels. Was pretty shocked at the amount of new noise with the lift. But hey, cause and effect.
  10. Nov 23, 2021 at 9:58 AM
    #110
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
  11. Jan 28, 2022 at 12:56 PM
    #111
    thc
    thc was once cool
    Tim
    Vermont
    2021 Sport
    Where specifically are people putting the pool noodles? Even better if you have pics?
    cryptolime, Whiskey21 and drvn like this.
  12. Jan 28, 2022 at 12:59 PM
    #112
    Meclizine
    Meclizine Well-Known Member
    CA
    '18 DCLB OR
    That's the gap between the bed and rear cab. After reading this thread I saw a pool noodle sticking out of a pile of dirt near work so I grabbed it. I love free mods.
    McPickle, TOKsTaco, Squirt and 8 others like this.
  13. Jan 28, 2022 at 1:00 PM
    #113
    VaToy
    Parts Unknown
    I got a black foam pool style noodle and ran in between the cab and the bed. I went over the gas tank andout 6 inches from the bottom. Worked like a charm, so much difference and I never had an issue with wind noise. I had it in the garage and for the hell of it I tried it. Worked great.
  14. Jan 28, 2022 at 1:43 PM
    #114
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    2nd gen leaking in here...
    I did a full dyna treatment especially on the back wall two layers of Dynamat extreme then a layer of dynapad and a layer of dynaliner.
    Loudest thing now seems to be the front windshield and my light bar wind noise, I think I'm going to try this mod and see if it helps further.
    Dynamat'ing the whole cab, roof, floor, doors and getting as much coverage as I could was definitely worth the labor and expense I appreciate it every time I drive my truck.
    Anything to cut down on just aggravating noise.
    :thumbsup:
    skyking3 likes this.
  15. Jan 28, 2022 at 3:29 PM
    #115
    Meclizine
    CA
    '18 DCLB OR
    I know what you mean somewhat. After taking my back seats and plastic trim out of my DC the noise level was horrendous. A single 80mil layer of Noico limited to where the upholstery would normally be did wonders, but by far the noisiest thing are those two vents behind the seats, at least until I get my rear wall fabricated.
    Key-Rei[QUOTED] likes this.
  16. Jan 28, 2022 at 5:02 PM
    #116
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Nice work. Going to try this too. My 2016 sings like a skill saw at times from wind noise. Good thing I was a carpenter for years and learned to tolerate it.
    My past 3 4x4's, 2 were Fords and one a Mazda B4000, had next to no road noise inside the cab. My first Ford was an 86 F150, with interior steel floors, steel ceiling, no carpet, and no noises after 13 years hard off road driving. Go figure.
  17. Jan 29, 2022 at 12:18 PM
    #117
    JTally
    JTally Member
    Jeff
    San Diego,CA
    '16 Tacoma TRD OR 4x4 MGM Access Cab
    Ha!!! I was saying the same thing about my 2016 access cab TRD OR 4x4 and 2005 wrangler soft top(full steel doors)!!! There isn’t much difference at highway speed
  18. Feb 1, 2022 at 8:47 PM
    #118
    Key-Rei
    Key
    Florida
    I got the 66 feet of D shaped weatherstripping did my access cab all around the strip at the front of the hood and in my cap gap still have about 9 feet leftover.
    PXL_20220202_010841665.jpg PXL_20220202_010835201.jpg PXL_20220202_013858678.jpg PXL_20220202_021738623.jpg
  19. Feb 2, 2022 at 7:39 AM
    #119
    gearcruncher
    Canadain bumper technician
    Golly , I dynamatted the complete cab of the truck including the headliner . Before I did this ,I took a rip on the hiway at 70mph and recorded the noise level with my sound meter .
    After I was finished sound deadening , I took the truck for another test drive using the same travelway and same speed recording the sound level as I drove .
    The best I could achieve was 11 decibels less . I must admit my stereo sounds fantastic .
    I went from 73 decibels down to 62 . I am second gen mind you .
    If you can get up to 15db just by adding the weatherstripping , you guys are very very lucky .
    Maybe the 3rd gen trucks have better sound deadening from the factory
  20. Feb 14, 2022 at 7:29 AM
    #120
    Chocaholic
    Chocaholic Well-Known Member
    Any advice on what you ordered (link doesn’t work) and how you attached it so it stays in place?
