window and power lock question.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Aug 10, 2009.
  1. Aug 10, 2009 at 8:56 PM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    ok recently my window clips (the part that holds them to the regulator )broke because the regulator is bent.
    got a new pair of clips and new regulator 60 bucks.
    what adhesive should i use on the clips to keep the window in?
    and now my lock problem. what is the power lock mechinisms real name?
    and has anyone had one go out? mine seems to work somtimes but on my driver side today and last night it just hasnt been doing the trick. problems only on the driver side.
    it did it this spring for a few days but then fixed itself.
    thanks for the help TW.
